White Top and Other Predictions
Darforce
Darlene
Buffalo, ny
Subaru crosstrek/ Mazda miata
Ok. I’ve obsessed about this way too much and studied all the media available and here is my predictions on the white top availability:
For the 2 door, as far as I can see the carbonized grey hard top is your option. That’s it...no soft top, no black, body colored. I’m fine with that. I live in the north where I need a hard top in winter and I can shell out $50 for fabric and make a bikini top For summer. Also, I always scratch my roof up so I might be proactive and immediately cover it in vinyl.
All the lit that mentions other tops, mentions only 4door. Im thinking they started with a soft shell knowing People will want choices for that. Listed is the same gray as the 2 door which I’m thinking will around the thousand dollar range. Then black and body colored. I am guessing both of those Will be about 2k To line up with Jeep prices ($2295). There shouldn’t be any reason you wouldn’t be able to order that in white as an aftermarket, but I’d bet grill, tie down and top in white option package becomes available later, so you may want to stick with the extra cost.
also guessing $3500 for Sasquatch, 3-4K for engine upgrade, and about $1000 for automatic.
Sighlense
Upstate NY
2015 Mustang GT - 2022 Bronco Wildtrak
Well, i hope you are wayyyy high on that guesstimate.
Compta38
Alabama
Ford Fusion
ain't no way the engine is going to be that high...
auto trans $1500-2000
v6 $1000-1500
hard top for 4 door $1300
mid package $2000
sasquatch $4000
I've seen some of you guys overprice options quite a bit. By the time you optioned up a lower tiered model it would make more sense and or be cheaper to get a higher tiered model in which those are standard.
lobbs611
Kyle
Independence, MO
2D JL Rubicon
It still lists the modular black top for the 2-door on Ford's site and it's standard on the Wildtrak. I'd be disappointed if the body-colored top doesn't come back for the 2-door by launch but I have zero doubt the black will still be there.
Darforce
Darforce
Darlene
Buffalo, ny
I expect lots of naysayers. Id love to hear how other people have estimated and what they came up with. I looked at the following; differences in specs and pricing for each model Bronco, comparable options on the Bronco Sport, comparable options on Jeep ( they seem to be trying to stick to that range, options/upgrades on other Ford vehicles, especially the Ranger.
Sighlense
Upstate NY
I'm not saying you are right or wrong, just that i hope you are way on the high side. Wish they'd just open up B&P already. Kind of sick of all the speculation.
RLW
Robert
Chattanooga, TN
2000 Lexus GS 300, 2022 Badlands, 2022 Honda Odyss
my guess for sasquatch is $4k. Based off the tremor package for the F250 costing $4k.
hardtop for 4 door ~$1,300. You can get one on a jeep for that. But i'm sure if they offer white or you want painted body color it will be more. So ~1,500-1,800.?
I have no idea about the manual transmission and upgrade to V6. I hope it is less than $3k.
To upgrade engines on the F150's it isn't that much. But who knows...
LoneStar
'23 Ford Bronco
Starting MSRP difference from Badlands ($42k) to Wildtrak ($49k) should mean that getting the V-6/auto and 'Squatch runs about $7k.
Other differences like bumpers and rock rails (on BD) and modular Hardtop come into play, but still I'd bet not much more than $7K.
RLW
Robert
Chattanooga, TN
Starting MSRP difference from Badlands ($42k) to Wildpeak ($49k) should mean that getting the V-6/auto and 'Squatch runs about $7k.
Wildtrak also includes Mid package and hardtop.
Then you lose the sway bar disconnect, rock sliders, bash plates.
Adding sasquatch to Badlands shouldn't be that much. It already has a bunch of the stuff. Lockers/gears/axle/suspension. So who knows?
But if I could get hardtop, V6/auto, Sasquatch on a Black diamond for $7k i would be good with that.
Darforce
Darforce
Darlene
Buffalo, ny
So for the top, Jeep has the grey for 1k and change but the body painted one is 2295
I took that into consideration. the upgrade between the OB and WT seems to make more sense. That adds Sasquatch, bigger engine and auto with comparable interior for about 10k (And painted top?). If you look at the difference between the big bend and BD specs, there seems a pretty high cost for the wash out, so you have to add that into the difference and you be right about at a 10k difference again. I think barring a few differences 9k at least for painted top, big engine and Sasquatch, (2k/3.5k+/3.5k+)
vrtical
Doug AI
GSMNP, TN
Fords
The 3.5 upgrade from 2.7 on my F150 was $600
20Bronco21
Amidst the Cornfields of Illinois
‘23 Balands ‘24 Bronco Raptor
Levine said B&P would be up in September, and my guess is sometime late on the 30th. Hey, it’s still September, and everything else is just conjecture.
Ajusaf
AJ
VA
Just to give you an idea what my fusion cost back in 2016 wth the upgrade pricing
Ford Bronco White Top and Other Predictions IMG_2430
OK_Hunter
Greg
Infinity g37
The white modular hardtop is listed in the accessories builder as an option for $2,499.
