White Smoke Normal?
pimpjuice
ocala, fl
bronco
This is my first brand new vehicle so I don't know if this is normal.
On my second day of getting my Bronco, it was idling in 77 degrees weather (Florida) and I noticed white smoke coming from the exhaust. Normally this means a blown head gasket (I think). It stopped after about a minute.
Last night I noticed it again. It seems a lot different from when it's cold outside. This smoke seems thicker.
Is this normal for a new car?
Engine sounds runs quiet.
2.7 outer banks, Lux - about 300 miles so far.
Ford Bronco White Smoke Normal? Screenshot_20211211-120654_Gallery
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Romano
Roman
Portland, Or
Bmw/Honda/Ford
My opinion is that color is not good. does it have any smell? oil, antifreeze? check the dip stick and check to see that its not consuming oil.
slohatch
Daniel
2026 Bronco Raptor
Every time you turn a vehicle off moisture is attracted to the hot exhaust and gets trapped inside. Then you turn a vehicle on and the exhaust gets hot again and boils off the moisture creating that white steam that goes away shortly. If it was a BHG it would be a very distinct sweet smell which would indicate coolant in cylinders. Your fine
mike8675309
Minnesota
If you were to rev the engine, you would likely see the condensation dribble out the exhaust. It's just condensation. If you have a head gasket leak you'll see clouds of sickly sweet white smoke coming out.
pimpjuice
ocala, fl
bronco
No smell of anything. Thank you, I'll check now.
Lifeliberty
Moonbeam👀
Columbus, OH
You're probably just breaking everything in, burning build residue. Take a 20 Mile drive to heat everything up. I probably wouldn't check it until 1000 miles again
BrentC
Brent
Calgary, AB
2019 F150 Sport, 2021 Bronco Badlands
^^^ this
JBHillCountry
Justin
Fredericksburg, Tx
2021 Land Cruiser, 2022 F250, 2022 Tahoe Z71
The white smoke turned out to be a cam phaser issue on the early Ecoboost Raptors if I remember right. My 2017 had it but I traded it before I could get it in the shop. Check the Raptor forum for the info. I started a thread on there for it.
okbob
North of the Red
71' u15, 66' u14, 66' u14
Leaking EGR cooler? Seen that happen on lots of diesels.
Bob Blaylock
Bob
38°29′ North 121°26′ West
2016 Dodge Dart
Water vapor is one of the products of burning hydrocarbons.
On a cold day, it is perfectly normal to see whiteish steam from the exhaust of a vehicle, especially right after a cold start. You say the temperature where you were was 77°, which is much warmer than I would expect to see this happening, but if the humidity is high enough, that could very well be a factor.
PSUTE
Western Maryland
Sierra
Smell it. Probably steam. If it's something to worry about, oil or antifreeze for example, you'll be able to smell it...
BE5OME1
Pete
2020 F150 SXT 4x4, 1967 Mustang, 1975 Bronco
Happnens every morning in my F150 2.7L, was told it was perfectly normal.
