Which model to choose?
mdfilip
New Hampshire
20 Shelby GT350, 22 Bronco BL, 29 Ford Roadster
I thought there was a thread which helped with model choice but I can not seem to find it. I'm looking for something that will be driven daily and realistically mostly street driving with little to some Offroad use. Unfortunately I want all the cool Offroad stuff which is making it had to choose. Ford Called me today to put my order in finally. Any help would be appreciated.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
mdfilip
mdfilip
New Hampshire
I just searched "trim comparison" and this came up. Hopefully this helps: https://www.bronco6g.com/forum/thre...-and-equipment-by-trim-comparison-chart.2749/
Thanks I have been comparing trim and that's what is making me go nuts... haha. I think I'm looking for some help justifying one model over another. I want to keep the cost down as much as possible as I recently purchased a GT350 as the fun vehicle and it's time to replace my daily 03 F150. When I did the reservation I picked a Big Bend but now not sure. Base, Big Bend or black diamond. :unsure:
604Bronco
British Columbia
www.bronco6g.com
Yeah, it's a tough decision for sure.
If you're mechanically inclined (which I am not), then a Base model is ideal as you can build your own vehicle, but have a solid foundation. But any trim level will be competent enough to take off-road - It's just the level of off-roading you want.
I took the comparison charts and just went through and circled the options I needed, the ones I "wanted" I'd put a star next to, and the ones I didn't care about I left off. You'll likely be able to figure it out from there.
Sascrotch
International Space Station
Jetpack
Personal recommendation: Base with Sasquatch.
You miss out on some creature comforts, but you get all the off-road goodies except for sway bar disconnect which is only available on badlands. Basesquatch is great value.
mdfilip
mdfilip
New Hampshire
Auto or manual? I'm normally a manual guy but for daily driving I'm just not sure... that crawler gear is cool.
AcenTitus
Peter
MO
I’d say you want the OBX with high package (or lux if you’re able) and Sasquatch package. Doesn’t sound like you’ll need the sway bar disconnect so that should more than cover you in maximum comfort
dgorsett
colorado
F250, Mustang, Explorer
Worth what it costs alert, but my opinion: if your not going to heavy off road alot Sasquatch is overkill unless you just can't live without big tires. Big Bend if you like cloth, Black Diamond if you want Vinyl, both can be had (standard on Black Diamond) with locking differential, which would be wise. If you want Auto 4WD you have to get Black Diamond or Outerbanks, it's not available outside of Sasquatch on the Big Bend. Then look at wheels strictly subjective. Remember you can get aluminum spokes as an option on Black Diamond. The Big Bend, similarly equipped will be cheaper than the Black Diamond.
Finally, the Base Sasquatch is by far the best buy, but may not be just what you want. (I went non Sas Big Bend)
BigFootie
Wisconsin
Base - if you want to do all the mods yourself.
Big Bend - if you want signature lights.
Black Diamond - if you want marine grade vinyl.
That's about it.
Plus
Outer Banks - if you want to jump mall curbs with Adv. 4x4
Badlands- if you want to climb rocks or get mid with MT.
Wildtrack - if you want to haul butt in the desert.
:cool: :cool:
Sergeant Gearhead
Missouri
If you want to do mostly street driving but still have some off-road credibility, I'd be led to believe a Black Diamond would be your best route. I'd also think you may want to skip the Sasquatch if you're not going to off-road it on a regular basis because the big tires take a hit on your fuel economy.
Best of luck with your Bronco!
-SG
mC.242
2021 Big Bend 4dr (sold)
I went Big Bend, added the 4.27 elocker. Upgraded to good 33" AT Tires. 4dr, MIC top, 2.3L, AT. All in around $42k. Great daily driver and enough off-road chops for anything I'm willing to do. But just my $.02
CMillBronco
Craig
2024 GMC HD 3500 AT4, 2022 Toyota Tacoma TRDORP, 2023 4Runner TRDORP
I just ordered last week and went through this as well, I finally realized it's all about how you're going to use it. The Bronco I ordered was for my 16 yr old son so Base with zero options, If I was ordering it for me would be a Badlands SAS, for my wife Outer Banks Lux.
