Wheel Weight Question
Batson35
Ohio
Black Diamond 4Dr & Badlands @ Dr
Has new wheel balanced to today and one of the 4 weights is stacked on top of one of the others...never seen that before.
Thoughts?
Ducati1098
Every time I see that, I can’t help but think the person doing the balancing was just lazy and/or incompetent.
It’s not hard to take the time to do it correctly.
But I mean I guess if it zeroed out and they don’t come flying off.. 🤷‍♂️
KreeHBronco
Kevin
Bay area California
2026 Badland 4-dr Manual
I would take it back and have them add the proper sized weight (vs two piggy backed). I am pretty sure these are designed to be attached to the wheel, not each other. Maybe take photo so others can comment.
Batson35
Ohio
Ford Bronco Wheel Weight Question IMG_1542
also scratched the F outta the rim removing factory weights…I’m going to show them but I don’t want them working on my stuff again!
Ducati1098
Yeah that’s just amateur hour shit.
Batson35
Ohio
Another question if the original TPMS sensor was moved to the new wheel does it need reprogramming?
65CarryAll
IL
The last 2 door Blazer (ZR2)
I would not trust them to fix this while not causing some other cosmetic damage. Show them your picture and request they give you new weights so you can properly clean the rim and reattach them correctly yourself.
I did this once when I noticed the tech didn't clean the rim and placed the new weights on top of the remaining foam from previous weights. They were starting to come detached before I even mounted the wheel! Since the wheel wasn't driven and no weights fell off I knew exactly how many were needed and where to place them. Plus, I didn't have to worry the shop tech would scratch or scuff my wheels.
Scooter M'Gee
Cincinnati, Ohio
2025 Ford Bronco Squatch 2 Door
Exactly why I always use balancing beads.
Batson35
Ohio
Went to Ford Quicklime to have it redone...those guys: "What dummy double stacked these"
