Wheel/tire take offs questions
broncocoy
Minnesota
2013 Audi A5 Cabriolet
I am seeing some good wheel and tire take off deals in my area on Craigslist. For the right price I wouldn't mind picking a set up as a "winter" setup. how hard is it to move the TPMS between sets? Can a tire shop do this easily? I am not familiar with how this system works on these, is it affixed to the rim or the stem?
Cybindustries1904
Tony
Discovery bay
23 Raptor, Mach E GT
you can add tpms to any set of wheels
Beachin 74
Delaware
Here's my take. Buy an extra set of sensors for the new wheels/tires.
Every time a tire tech monkeys with the mounting/balancing (which is required to change sensors) you take a chance damaging the wheels. Not to mention the added cost to mount/balance the tires every time.
Even if folks are going to sell their take-offs, the take-offs will be worth at least $300 more w/sensors installed if the new owner doesn't have to buy new sensors and visit the tire shop.
1979
Ben
Baltimore, MD
2023 Bronco Raptor
Definitely buy a second set of TPMS. They’re fairly cheap on tirerack.com
Techun
Pa
BD, 2.7, MIC, 4dr
Or just don't buy another set. I never had any on my winter wheels
LowerSlowerDelaware
Lee
Lewes, Delaware
Subaru Outback, Chevy S10
Bought a set of OBX takeoffs and the BCM recognized all 5 without a TPMS tool or Forscan.
TPMS only costs about $5-6 at most. They're were just constrainted due to the Wu Flu since most or all are made in the P.R.C.
broncocoy
Minnesota
So if I find a set of Bronco take offs the TPMS sensors should just connect with my car automatically?
jd-ford-hd
Tennessee
‘16 Explorer, ‘13 F150, ‘99 F350, '74 Bronco
Yes they will.! Levittown Ford sells a genuine Ford 5 sensors kit with sync tool for less than $200. I bought a set of Sasq. takeoffs and did not think about them not having sensors. The seller had them removed to put in his aftermarket wheels.
Ford Bronco Wheel/tire take offs questions 512836C7-DC0B-4473-B8BB-65B379A7B510
MnLakeBum
MN and FL
‘18 Range Rover Diesel
I had ordered the set above from Levittown Ford but they were going to take 2-3 weeks I paid $45 from the tire shop that is installed my 35” Falken’s.
JT58Bronc
JT
Fl
I changed wheels on my C6 Corvette recently. I had never changed TMPS sensors before. Instead of using the old TPMS sensors I bought new ones. I had to shop around as prices varied a lot. I installed the new sensors myself then brought the wheels and tires to a tire shop. Just be careful not to over tighten them. Or under tighten them. I had one too loose and lost air on a drive and had to find an air pump fast! They did not connect automatically. I had to buy a scan tool, it was like $20.00 from Amazon to get them to connect. The Bronco may be different and the sensors may connect automatically.
‘21OBX
90Bronco19
2022 bronco outer banks
I bought a takeoff set with sensors they connected by themselves and have worked flawlessly. Once they have the ford frequency I believe they will connect again. So you wouldn’t have a problem swapping back and forth between wheels. When you buy new thats where the activation tool comes into play.
JJ Bronco
Justin
Columbus Ohio
Lexus RX
Thank you in advance, I really know nothing of tires.
Does anyone know if the Black Diamond upgraded wheel on General Grabbers would fit on a non SAS BB without changing the driving dynamics and etc?
So for example, I prefer the look of them, but don't want to drastically alter my daily driving experience.
broncocoy
Minnesota
Yes they will, you will notice no difference in the drive ability as they are both in the 32” range. The stock non sas Bronco can run up to 33.5”s with no rubbing clearance or drivability changes. If you made the swap from BB wheels to the upgraded BD wheels you would notice no noticeable speedo changes or MPG changes.
JJ Bronco
Justin
Columbus Ohio
Lexus RX
Thank you!
Side note: I posted my question because I saw the BD wheels and tires being offered for a great price on here. Almost too good, so I was very hesitant and decided against it. Turns out it was a scam and the poster was banned.
