Wheel & Tire Setup Feedback
mig1980
El Dorado Hills, CA
2016 Corvette Z06
Good day everyone. I am looking to pickup a set of Method MR305 (18 x 9 ET -12) and Toyo Open Country R/T 37 / 12.5 / 18 on my 2023 Wildtrak (which is completely stock).
I am trying to figure out the following:
1. The wheel and tire setup would push out about 1.75" from stock. How would that look and would I have problems with rock slinging?
2. Does anyone have any input on this tire. How good is it for street/highway driving? Road noise compared to OEM?
Anything else I should be aware of eith this setup like, would I require a lift from stock to clear the setup?
PWillette
Parrie
Maine
What is your use case? 37's will fit but that much offset most likely going to rub when flexing.
Looks is subjective...at -12mm offset you will be well beyond the squatch flares so yes, things will be flinging.
The Toyos are a good all around tire IMO.
Monster1926
GMC Sierra 2500HD
It will rub at full lock going forward and while reversing unless you chop the crash bars out or throw on min 3 inch lift. Here’s mine on 37s on stock sas suspension and with a 8.5 wheel and 0 offset
Ford Bronco Wheel & Tire Setup Feedback IMG_2223
Ford Bronco Wheel & Tire Setup Feedback IMG_2224
Ford Bronco Wheel & Tire Setup Feedback IMG_2222
Ford Bronco Wheel & Tire Setup Feedback IMG_2221
mig1980
mig1980
El Dorado Hills, CA
2016 Corvette Z06
This is great feedback everyone and is what I assumed. My use case is primarily street/highway driving with the occasional trail runs (but nothing major).
I will look for wheels with a 0 offset or lower to not affect deivability, which is my primary concern.
Cooldude
Mercedes e400 cab, edge titanium, ford f150
You didn’t have to cut the crash bars correct?
Monster1926
GMC Sierra 2500HD
I haven’t yet. Since those pictures I threw fox coilovers on it and have 0 rubbing issues on road. Off road is a different story.
JL8jeff
Ewing, NJ
Here's a picture I grabbed off here of someone with 18x9 -12 offset. They do stick out a bit past the Sas flares. I think the +6 to 0 offset works best for 9" wide wheels.
Ford Bronco Wheel & Tire Setup Feedback bronco_18x9_-12offset
