What winch with ARB Summit bumper?
FreshKsig
Ryan
Idaho
FE Bronco, 22 BB Bronco, 21 Mustang Mach 1
I ordered a Smittybilt X20 Gen3 a month ago. Called today and still no updated ETA. So looking for other options. The ARB website lists under compatibility 3 Warn winches and the one smittybilt winch. All 10K winches. I saw that Maine overland put a Come Up winch in theirs. For those of you that have this bumper what did you put in it? Am I really stuck with using a 10K winch or can I stick a 12K in there? I have had the bumper and lights sitting for weeks and want to get everything put in but don't want to settle for the cheapest Warn if there is a better option. TIA
Nick@ApolloOffroad
Nick
Houston
www.ApolloOffroad.com
2022 Wildtrak | 2023 Raptor R | 2019 F-250
If the bumper is capable of fitting a Warn Zeon 10-S in it, then you can fit pretty much anything in there as the Zeon series winches are some of the largest on the market.
On our Bronco, I did a Superwinch SX 12K winch with the synthetic rope and I was very pleased with it.
The biggest thing to check would be dimensions.
Here's the Zeon 10-S specs:
Ford Bronco What winch with ARB Summit bumper? 0003723_zeon-10-s-winch-89611_625
And just for grins, here's the Superwinch SX12SR Winch:
Ford Bronco What winch with ARB Summit bumper? e8a443a15f8b40ba507875e5cd133138
Based on the design and dimensions, the Superwinch 12K SR would fit with room to spare and you'd be able to get the full 12K capacity that you're after.
If we can help get you setup with a winch for your bumper, please let us know. I have Warn Zeon 10-S and 10-S Platinum winches in stock as well as the EVO line and other brands like Superwinch, too.
Feel free to send me a message if we can assist.
Valhalla
Valhalla
Chattanooga Tn
I've got the 12k KO2 in my summit, fits fine the spool in spool out is a bit hard to see, but not hard to reach, I'd say that'd be your biggest hurdle is the engaging disengage being seen plenty of room for any winch with a center based solenoid..
Ford Bronco What winch with ARB Summit bumper? 20230401_131547
SvgOne
Daniel
AR
2023 Bronco 4dr, 2021 Jeep JLUR Diesel
Quick question, does the winch block the intercooler at all? I have tried to research and get pics to see, but to no avail. Thx!
Valhalla
Valhalla
Chattanooga Tn
I have a 3" body lift, so mine is different than stock. I will get you a picture of mine after I get home. Of course there is no way to build a sturdy winch bumper without some restriction. I believe the ARB is the best compromise. The front is open where the plastic grill is reducing restriction of air flow.
SvgOne
Daniel
AR
Thank you,much appreciated!
Valhalla
Valhalla
Chattanooga Tn
So it is hard to get a good picture. There is more space below my radiator and the top of the intercooler because of the body lift.
First picture is the holes they have in the bottom. Next I tried to get a birds eye view. Honestly the winch blocks more than anything.
Ford Bronco What winch with ARB Summit bumper? 20231025_231924
Ford Bronco What winch with ARB Summit bumper? 20231025_231951
Ford Bronco What winch with ARB Summit bumper? 20231025_232008
The next two are of where air flows by the fairlead and the grills.
Ford Bronco What winch with ARB Summit bumper? 20231025_232937
Ford Bronco What winch with ARB Summit bumper? 20231025_232944
SvgOne
Daniel
AR
Okay, so there are air holes on each side of the fairlead? Correct? Like in the last picture?
SvgOne
Daniel
AR
BTW...sorry for the questions, but that bumper is fairly expensive. It's one of those buy once, cry once situations. Unfortunately, I can't afford to cry twice.😆 and again thank you.
Valhalla
Valhalla
Chattanooga Tn
Ford Bronco What winch with ARB Summit bumper? 20231025_233145
Valhalla
Valhalla
Chattanooga Tn
Love mine, it takes the abuse I've dished out so far....taking it here Saturday...
Valhalla
Valhalla
Chattanooga Tn
Valhalla
Valhalla
Chattanooga Tn
Actually, when I got mine, it was one of the lesser expensive options. ( Full bar )
SvgOne
Daniel
AR
There are some less expensive options out now. The summit gives the Bronco a more nostalgic feel IMHO. Reminds me of the 80s and 90s stuff I used to see growing up. Once again, thank you. The pictures are much appreciated.
PEGB
Pete
RI
Eruption Green Badlands Sasquatch Hardtop 4 door
Also, I reached out to ARB USA (they have pretty responsive CS), their reply was they state 10k because that’s the highest they tested it to. The Warn Zeon 12k and 10k are the same size physically.
