What is this
DrFunzo
Derek
MD
F350
I attempted to install some sick skids yesterday and was unable to get the driver side to sit flush. I gave up and went to the passage side without a problem and realized I have something rotated on the tire side. I'm not sure if this is a spacer or a flag nut. I'm trying to decide to cut it off with a grinder, or so I take it to the dealer. I'm a little concerned something is loose and allowing it to rotate, but this bolt should be torqued to 350. I can't rotate it by hand, and honestly haven't tried to loosen the shock bolt myself. Any thoughts?
Ford Bronco What is this 20231123_120845
Ford Bronco What is this 20231123_120841
kodiakisland
Arkansas
Tighten the bolt and that will rotate up where it is supposed to be.
DrFunzo
Derek
MD
F350
The problem is this bolt is torqued tougher than I can manage at home. And if
Something is rotated, then doesn't that mean the bolt has loosened... I have tried to loosen or tighten and I can't get it to budge
Felix808
SRV CA
You need a good impact gun. Those bolts are torqued over 300 lbs. I think 360 lbs If I recall. But yes it's supposed be 180 from where it is now.
