What has broken or been recalled?
Check what you have had break or Recalled. Check all that apply
  • Total voters
    66
Hoss360
Fairborn, OH
2021 Bronco 2 door
I just had this one as well. Replacement appointment tomorrow morning.
How did you set that up? Did you show it to your dealership? Or can you just call them to order the part and install it next time you're in for an oil change?
2ata
Bob
Curr.: 2021 Ford Bronco; '77 924, '01 986, '02 911
@Hoss360
Warranty item, stopped and showed it to them, they took pics and turned it into Ford. Called me when the part came in.
Mrpenn46
Nebraska
Badlands - Cactus Gray
Oil/Fluid leak.
I had a valve cover gasket on my 2.7 leaking a little bit.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Snowdogyyz
23 Ford Bronco Wildtrak
Just the windshield recall so far (6k miles).
‘21OBX
Ken
90Bronco19
2022 bronco outer banks
All,
If you need replacement parts we can get a group together to go to this abandoned mountain to salvage parts.
It could be a fun road trip to Dearborn.
(JOKE)
Sounds like a plan I can grab a m210 front diff, half shafts, and front drive shaft 😂.
Paul Gagnon
Paul
Sherwood Park, Alberta, eh?
'79 Mustang, '92 Explorer, '10 F-350
This... seems to be a widespread issue
Has Ford acknowledged this yet?
They haven't not acknowledged it. As far as I have heard, they have replaced every one without question. I had this same issue with my 2010 F-350 when it was a year old. It's not specific to the Bronco, just seems to be more common than others. Must be an issue with the mould for the casing. Either the grooves are too deep or the casing itself is too thin.
equitasforall
Out of the country until late 2025
2021 Bronco Badlands
5900 miles. 11 States. 5 months. May break everything tomorrow, but flawless so far.
Djveks22
Los Angeles
None
Were there fixes in my2022 vs 21? 23 vs 22 hopefully if I have to get 2023, there will be fixes
BottleShark
BottleShark
TJ
East Texas
Nautilus, Samurai, 12v Dodge, Fiero, Karma Ghia
Ksjrb03
Tx
F250
You forgot the rattly shaky windows that get caught when opening.
BottleShark
BottleShark
TJ
East Texas
O dang!!! We are at 50/50 on issues vs no issues. That sucks.
BottleShark
BottleShark
TJ
East Texas
Don’t think there is a recall or repair for that.
mtap
Mervin
Cape Coral, FL
Toyota Tundra, Hummer H3, Harley Sportster
E brake switch broken by my ignorance.
How did you break yours? My dealer broke mine when i took it in for an oil change but they won’t fess up to it. They also broke two other broncos in my area….
Cokeman1959
Ralph
Georgia
2021 Telluride
Amen! This is absolutely annoying and ridiculous that you cant even roll down your window just alittle bit without it rattling. Come on ford.
