What dis???
kodiakisland
Arkansas
I just found this unplugged and hanging loose. I plugged it back in to where it seemed to come from. I’ve not had any issues or warnings and have driven it every day this week. No idea how long it’s been unplugged. This is the front end of the gas tank.
Any idea what these wires are for?
Ford Bronco What dis??? E58E2C47-6F05-4976-A460-E1B8785433CF
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Oh no - You plugged that back in?!
That gives Mike Levine fuel to power his space ship with all the data he collects from your Bronco.
... Actually, I'm just here to see what the real answer is. I'm very curious now :ROFLMAO:
kodiakisland
kodiakisland
Arkansas
I couldn’t actually see into the back side of the plug in to see if it just holds the wires or if they are connected to anything. I did consider not plugging it in since everything works, but it is too clean to have always been unplugged.
Rick Astley
Up Doug's ass
d
+3 whp, that's what that is!
Like stickers on a rice out Honda, unplugged sensors on a Bronco add WHP.
It's only a 3-wire sensor, so probably fuel flow related if on the tank.
kodiakisland
kodiakisland
Arkansas
I would think if it was a sensor for the fuel system it would have thrown a warning light at least.
JohnnyBronco
Pennsylania
X4
4 wire trailer harness? 4th is supplied by ground. A VOM would give you more info
Ha, 1 wire per hp
kodiakisland
kodiakisland
Arkansas
broadicustomworks
Hanging Rock, North Carolina
Interesting.
Truly.
I am amazed you didn't get some wonky evap code.
Maybe, just maybe you noticed it directly after it popped loose and the ECM didn't have the chance to analyze data and pop a code.
Very odd, indeed.
  • Like
Reactions: Cat
MadMan4BamaNATL
Ray
Atlanta
Not sure exactly “what dat” is, but all that dirt all over that undercarriage is just downright sexy AF! 🥰
DIRTS. GET SOME!!!! :ROFLMAO:
710-oil-614
Cal
Columbus, Ohio
2023 Maverick Tremor, 2010 Toyota Tacoma
Kodiak is how you love and own your Bronco. I've enjoyed his posts and journey he's taken with his Bronco. Faced the negative and the positive with the same great attitude and rides the Bronco like it deserves to be.
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
Here's another possibility: Connector C435 - Fuel Tank Pressure Transducer. Part of Harness 14407 for the 3-door.
Check the wiring closely to see the specific colors of the 3 wires.
If it's C435, the wires will be:
  1. Violet/Green
  2. Yellow
  3. Brown/Blue
If those aren't the colors, report back with the specific color combinations, and I will look for other possibilities.
Ford Bronco What dis??? C435 Wiring
Ford Bronco What dis??? C435 Fuel Tank Pressure Transducer
68 galaxie
Jax Fl
1968 galaxie /2017 f450 /2021 f150 / 2023 Wildtrak
could be a low fuel sensor
