Superds
Superds
ND
My wife’s Audi SQ5 came with auto start stop. Pretty jerky, especially in sport mode. Luckily, I found Carista had an app that could disable it. Well worth the small fee to do it.
I think FORScan has options to do it on some Fords and if not yet, they are probably working on getting it added to future updates.
Spooled
Republic of Texas
I have no experience with turbos, but I heard they are a plus at altitude? My old Land Rover with squirrel-cage 4cly is a complete dog over 10,000 ft. If the new Bronco engine with turbo does well at higher altitudes, that would be a plus.
Turbocharged engines are absolutely better at altitude. They will lose less power vs. their naturally aspirated competitors.
frinesi2
MD
'92 Pajero 2.5TD, '99 Land Cruiser '15 Golf TDI
Turbos were invented to address power loss experienced by aircraft engines at high altitudes.
JimmyDean
Louisiana
As others have stated, turbos, or any forced induction (including nitrous) gives major performance boost at high altitudes over NA. modern turbos are the best at it because they can be tuned to account for it on the fly and adjust boost accordingly, whereas S/Cs are a fixed value based off of engine speed, can be adjusted with pulled changes though. Nitrous is an interesting one that I've seen run before, using very small constant squirt (not like a 100 shot for a few seconds on a drag strip), but like 5-10hp constant shot to make up for the decrease in air density, but this is a constant cost adder
JimmyDean
Louisiana
frinesi2
MD
Nitrous injection was also first used in aviation engines to improve high-altitude performance (also water-methanol injection).
JimmyDean
Louisiana
TIL, did not know that.
Nickp
Nick
Phoenix
Auto start stop sounds way better if you get a manual. Only turns off if the car is in neutral clutch out, as soon as you start to clutch in it turns back on so there’s no delay like an autotragic
SpursFan
TX
350r, F150, Expedition, Cayenne and the others.
If they do the fake engine noise thing then I will call in every favor ever owed me by every software and electronics person I have ever met and we will work non-stop every single day and through the night until we have figured out a solution to permanently disable it.
It's easily turned of through Forscan and pretty sure auto start stop as well.
