Water in Catch Can
rtd16
Ryan
NY
2022 Bronco Big Bend
The photos show what I found in my catch can today changing the oil. Last two oil changes there was only about 1/8 to 1/4" of actual oil in the bottom of the can. This time as you can see it was about 2/3 full with fluid, seemed like water (thought I smelled fuel but I think it is going to have some amount of fuel smell from the crankcase anyway). I believe it's water because the normal amount of oil was sitting on top and on the upper screen like mud. Anyone seen this before? Doesn't seem normal to me. Coolant level is still within band. Didn't do anything crazy like deep water off roading or anything. Checked all the hoses were connected properly, so what's in the can came from the engine. It was about 5K miles or so between changes. I understand condensation collects in the crankcase with temperature changes, but that amount seems abnormal to me.
Ford Bronco Water in Catch Can E77B8675-B40D-4A7D-B25A-4034D4D3E985
Ford Bronco Water in Catch Can D63D8845-E99D-4D7D-85EE-241B62724080
LockedBronco
Frank
PA
1972 Bronco
Do you do a lot of short drives?
rtd16
Ryan
NY
Not really, my drive to work is about 30 minutes and I don’t do many short trips in between. Thanks
BigHoof
PA
Ram 2500
Short trips. Moisture has no time to burn off. Sometimes the fill cap will even get like a pudding on the bottom.
Mlarv
TN
Yup science is at work. Cold moist air has a nice warm place to leave the moisture. The old PVC caps would do the same thing.
rtd16
Ryan
NY
Thanks. Just seemed like an awful lot of water even though some condensation forms in the crankcase
Wildfire1
Paul
Nfld, Canada
1993 GMC 4X4 / 2012 Mustang convert
That’s a lot of condensation in that oil And I mean a lot. Here’s mine at 3000 miles. I have a 2.7. If it’s not condensation keep an eye on your coolant level. If that keeps up get some dye put in the coolant and check if it ends up in the motor. That don’t seem right.
Ford Bronco Water in Catch Can F360DD18-CC4A-43CB-8803-9A41C4221E44
If
Ford Bronco Water in Catch Can B8546ECA-1E23-452F-AADE-2EFBA25F406D
Ford Bronco Water in Catch Can 116AF07D-CC52-43ED-9FCA-9E36F17AA576
Ford Bronco Water in Catch Can 90A19428-FC7C-4560-B0FD-DDA61C8F183D
NC_Pinz
Central NC
2022 Ford Bronco OBX w/ Squatch, 1975 Ford Bronco
