Water Fording
drive21bronco
North East USA
2021 Bronco Black Diamond
I'm not sure there is much reason to speculate further, but I will, haha. It was a marketing gimmick or tool. The Ford Bronco was built specifically to compete with the Jeep Wrangler, so Ford picked a number greater than 30", 10% more in fact.
You do not want to use the air intake height as the measurement for fording depth. Water moves, flows, and therefore will rise and fall. If you enter water at an inch below your air intake, you may or may not ingest water depending on speed and terrain. The water will "slosh". It is also heavy and if it is moving, it will push your vehicle around.
Ok yea that makes sense. So it’s not really the fact that a component at lets say 34” high will be compromised but the fact that pushing through the water above 33.5” at a certain speed would cause possible water ingestion into the air intake.
AcesandEights
Ace!
Oregon
DR650
It's all of it. You've got a fan that's spinning, electrical components, air intake. You might burn up a fan clutch, injest water, have the fan throw water on top of or into an electrical connection and cause a short. There may be acle or trans breather tubes, etc.
It used to be that manufacturers recommended no deeper than the hubs, because you had to re-grease them. MHO is that marketing is moreimportant, so they decided you can reasonably go 33 inches, or whatever it is. The manual though will say if you do, it is severe service and requires additional maintenance. That's not a warranty issue, unless you dont read the severe service maintenance schedule. So, go deep, but remember to check fluids and re-grease components, just like knowledgeable wheelers have always done.
jaeggernaut
BMW M Coupe // Volvo P1800S // Caterham CSR 200
Did a google search and found this old thread. My friend has a built up TJ and said after going in deep water it’s good to get your differential serviced because of the water.
is that true for our broncos too?
Deleted User 5719102
Who's
On a Lake
22 2dr
As long as your rear and front differentials are in proper working order, ie., no seal leaks including diff cover, and your vent tubes are high enough then your ok.
jaeggernaut
Thanks Grumpy.
do you know if the stock location of the vent tubes (sasquatch) is particularly high?
Mishra42
Pittsburgh
Thanks Grumpy.
See my thread the diff tubes are actually up near the hood your limiting factor is the fuse box under your steering wheel. After my adventure the alternator hiccuped a little when the auto shut off system triggered and wouldn't restart, but I just did it manually and that went away after I cleaned the engine bay. They're tough cars.
MFP2241
WV
2 Door Antimatter Blue BaseSquatch
I feel like (if you're sticking with the stock configuration) a Squtached 2.3L is probably your best bet to have some fording success. Thought I read this was why the Everglades wasn't offered with the V6.
Ford Bronco Water Fording image001
JasonNEK
Jason
Saint Johnsbury Vermont
F150 and badlands.
I don’t feel I can go off roading with a lot of water or mud. At least until there is a alternator relocation kit. The bronco is a awesome off road vehicle until the alternator gives out. I had to replace the alternator and the 300amp fuse. If I have to replace the alternator every extreme ride. I’m not going.
MNBigfoot
MN
The decal on the Everglades shows the Safe water fording mark 2" above the top of the tires, the alternators on both the 2.7 and 2.3 will be submerged at the level (see blue line). So it appears that is simply a false claim that keeps on getting repeated on here.
Ford Bronco Water Fording 2022-Ford-Bronco-Everglades-decal (1)
Ford Bronco Water Fording fordinf 2
