Warnings when starting
pimpjuice
ocala, fl
bronco
I typically keep my Bronco parked in my garage with the doors off. Every single time I start it up in the garage, I get all this warnings. It usually takes about 5 - 7 seconds for them to clear but the E Break is always engaged (without me engaging it).
It only happens randomly when I'm parked anywhere outside of my garage with the doors off (never happens when doors are on)
I've tested all theories. On inclines, near walls where the sensors will go off, flat surfaces, with seat belt engaged, etc. It doesn't matter, it's always random outside of the garage.
Anyone else have this issue? I don't want to take it into the dealership if it's normal.
Also anyone else have to sometime turn their radio off and on to get sound to come out? (Bluetooth connected, will show the song is playing but not sound until I press the power button off then on again. Then it works fine)
Ford Bronco Warnings when starting 20220525_161457
Ford Bronco Warnings when starting 20220525_161459
Ford Bronco Warnings when starting 20220525_161502
Ford Bronco Warnings when starting 20220525_161506
Redrooster33
Maple glen
Honda pilot
Yes! This is happening to me too. First with doors on, on a few occasions. I took it to the dealer, they ran tests an said everything was ok. Then, I recently took my doors off and it happened almost at every start. I put the doors back on and haven’t had it happen since.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there! Send a message to us with your VIN and the name & location of your Ford dealership, along with some more details about your situation. I’ll look into this for you. Thanks!
pimpjuice
ocala, fl
bronco
Does your park brake automatically engage as well?
Redrooster33
Maple glen
Honda pilot
It does. But when I hit the gas, it releases.
broadicustomworks
Hanging Rock, North Carolina
Same (with the doors off).
Oddly enough I have found it happens rarely if I buckle the seatbelt PRIOR to starting it.
On occasion it will still do it, but it was every time without buckling up first.
Who knows?!
pimpjuice
ocala, fl
bronco
My does nothing even when I hit the gas. I have to press the button to release the brake.
Did Ford reach out to you? I'm currently PM them with my info. They are looking into it.
Redrooster33
Maple glen
Honda pilot
I just sent Ford a message. Thank you for getting this started. Please keep me updated. I’ll do the same.
pimpjuice
ocala, fl
bronco
Who knows?!
I thought that was the issue but when i buckle first it doesn't change anything. I even thought maybe it needed to load so I would press the ignition without my foot on the brake to turn in the screen and let it load. Nope, no difference.
Bl4ckf1n
mark
florida
Jeep/Explorer
i also get this almost every time with doors off. been crappy down here in florida lately though, so i haven't had them off in a while.
JMY217
New Jersey
2022 Ford Bronco Outer Banks Sas/Lux/Soft Top
Same happened to me, almost exactly as you described. No issues once put back on, but haven't taken them off a second time yet.
BroncoBenny
Ben
Provo UT
1972 Bronco and a new one too
Same exact issues with all the same warnings for me when I took the doors off. Glad I am not the only one. Maybe Ford will get this fixed. Wierd that it engages the parking brake too. Thought it was a fluke the first time it did it. But it has been doing it every time. Even when I have my seatbelt buckled.
NotaJeep
Fred
Denver, Colorado
F-150
Same issue here with warnings and E brake engaging automatically. You get any response from Ford?
Ford Motor Company
Dearborn
Hi there. This concern doesn’t sound like something we want you to experience with your Bronco. Could you please send us a PM with your VIN and the name and location of your Ford dealer? I'd be happy to look into how I can assist you on my end.
WLDTRK
Ford Escape
Mine also throws a bunch of warnings and engages the e-brake on startup. If there is a solution I would love to keep it from chiming a dozen times everytime i start up with the doors off. and the e-brake is so annoying. I just assumed it was normal for all these things to happen.
