Warning: Bronco bolts strip easily
BlueOvalBandit
Kenneth
Anaheim, CA
Tacoma
The OP doesn't mention which particular "bronco bolt" was stripped, but I just did some audio work on mine and noticed the torque spec listed for the grab handle by the driver's door hinge is a very low 80 inch pounds (less than 7 ft lbs) so if you're applying much torque to them it'd be no wonder if they stripped.
I have to wonder what those are actually threaded into. With such a low number I wouldn't be surprised if it was just plastic. They seemed to have a ton of flex when I grabbed it at the dealer event.
To me that's just asking for breakage trouble.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
I think the bolts are also Torx Plus, so slightly different shape. I noticed my t40 is a Hair loose. Need to get a t40 torx plus
You are correct. It's a Torx Plus (TP)
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
40IP, not T40?
What is your information source?
I’m not questioning the accuracy of your statement. Just looking for some external confirmation. Thanks.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
40IP, not T40?
Umm... I own a Bronco... I develop mounting hardware for Broncos... and i've tried Torx, Torx Security and Torx Plus... soooo that's my my authority on the subject :)
You need a TP40 (Torx #40 PLUS / Torx Plus 40), at least on the front bumper parts. I've used a TP (Torx Plus) on some internal things.
You can test this yourself. If you use a Torx, you'll notice there is a slight play. Use a Torx plus, no play.
MaverickMan
Shane
Were gonna need 2 forms of ID and a letter of Reference from your 8th grade principal to verify your authority. :ROFLMAO:
WuNgUn
Ontario Canada
2 door Squatched
really, most people don't know how to properly use a screwdriver. they do not hold the driver straight and use adequate pressure to hold the bit tightly into the fastener so magically the hardware is at fault. there are reasons people cannot assemble ikea furniture neatly.
i remember sitting through a few classes about how to properly use a simple tool while in the us army's aviation mechanic's school. at the time i thought it was insulting to need to sit through the classes, but as i get older there are so many who could benefit from such an education.
the truth is if you are going to do your own work, you need to invest in quality tools and some quality instruction on how to use them.
The Robinson head eliminates almost all downfalls of the stupid, AN Philips head. It's a shame Robinson lost out due to patenting and licensing. 🤷🏻
But Torx is definitely better than both. Except with Ham-fisted shade tree mechanics over torquing everything!
HeritageRider
Portage, PA
2011 Xterra Pro-4X 2014 Focus SE 5MT 1994 H-D
Wish websites would say if their products were made in USA or elsewhere. You can never be sure these days, even with so-called American companies.
The FTC should make it MANDATORY that they specify the country of origin.
duc135
Duc
Los Angeles
2004 Jeep Grand Cherokee, 2014 Ram 1500
But that pedal wrench is actually very useful/necessary for removing pedals on bikes. A standard wrench is too thick.
While it can be used to remove/install pedals, that bottom wrench is actually a cone wrench for adjusting hubs and road bike brake calipers. Pedal wrenches are longer to help remove pedals installed by gorillas.
HotdogThud
mk6 gti, '21 MoarDoor
Has any manufacturer EVER provided a tool worth a damn? I'm surprised they didnt include these wonderful bits...
whoa whoa whoa there compadre. Park Tool makes some of the best damn bike tools ever. Some of their stuff in my toolbox is pushing 30 years old and still works flawlessly
Hossamus Prime
Arkansas
www.instagram.com
21 BadSquatch,‘21 ExplorerST , RIP 84 & 90 Broncos
Welp I stripped a couple on my SAS wheel’s beauty rings… used Torx Plus 40.
pan-y-cerveza
Manitoba
Tacoma Pro
Ha. I chuckled at OPs photo.
That particular cone wrench sucks to use but it's a damn tough tool. Tougher than most cone wrenches.
Blitzjb
Joel
Long Island
2021 Ford Bronco OBX
Torx Plus !!!
smoot618
Chase
Nothing
I unfortunately used the tools they give you and stripped 2 bolts. Is there anything I can do to get them off? It's the three bottom on mod front bumper so I might mount something in the future. Any tools anyone recommends I get, especially to avoid stripping anymore.
