ironexecutioner
Rick
Charleston, SC
2022 Bronco Raptor
Mind if I ask who you used for the PPF? Did they do correction before applying?
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
vrtical
vrtical
Doug AI
GSMNP, TN
Fords
Added winch with the following components:
Warn VR EVO 10S
Turn Offroad winch plate
Frame horn reinforcement brackets - TD's / Mike's
Stinger 500 amp relay wired to upfitter
Factor55 upgrades
FP winch cover
Ford Bronco vrtical's Bronco Raptor Mod Journal 1728393261849-yd
vrtical
vrtical
Doug AI
GSMNP, TN
Fords
Added 1/2" body lift using 2" pucks UHMW-PE. Utilized factory body bolts and replaced the 2 front ones with longer bolts.
Ford Bronco vrtical's Bronco Raptor Mod Journal 1000004262
vrtical
vrtical
Doug AI
GSMNP, TN
Fords
Added Ford Performance Procal Tune what a nice upgrade.
Ford Bronco vrtical's Bronco Raptor Mod Journal 1000004338
vrtical
vrtical
Doug AI
GSMNP, TN
Fords
A couple months back I updated my rear pods to MTI Acoustics housings and 6.5 Focals. I also did the Forscan changes for EQ and rear pods settings. This was my last speaker change I replaced all the other speakers already.
Ford Bronco vrtical's Bronco Raptor Mod Journal 1000004859
Ford Bronco vrtical's Bronco Raptor Mod Journal 1000004861
Yesterday I started the install of a Kicker Key 200 and a Plug N Play Kit 11. First I had to find a place to put it because I have a GMRS unit above my glovebox and Fords trailer control module bolted to the metal bracket below the steering column. I found a spot that made it easy to access and it's not blocking anything. Its pretty secure and not going anywhere. I partially wrapped it in dynomat and ran both pos/neg to the battery to avoid any feedback issues.
Ford Bronco vrtical's Bronco Raptor Mod Journal 1000005417
Next I set the DSP up and went through that process with no issues. I put the mic on top of the center console arm rest as that is more center than on a headrest. Soo far I set the front gain only to a 1/4 and left the rear at 0. Looks like I can crank it to about 22 on the volume before seeing any clipping. I will keep fine tuning it but over all its obviously better and pretty clear now.
vrtical
vrtical
Doug AI
GSMNP, TN
Fords
Added Turn Offroad side molle panels for additional overland storage and protection. @Turn Offroad
Ford Bronco vrtical's Bronco Raptor Mod Journal 1000004484
Ford Bronco vrtical's Bronco Raptor Mod Journal 1000004485
