Currently Available 3 Week backorder due to high demand.
https://vectoroffroad.com/collections/new-bronco
6th Generation Bronco Tube E-dock(current backorder lead time is 15 business days from date of order before shipping)
Proudly Made in the U.S.A.
The 6th Generation Bronco, is heavily steeped with exterior cues of classic styling. The Vector Offroad E-Dock will help carry that classic styling through the interior of your new Bronco as well. The Vector Offroad Bronco dock sits closer to the passenger cockpit, allowing for the use of shorter device mounting arms. This keeps devices much more stable than longer arms. Our edock does not require use of the dash and device mounting arms for stabilization.
The Bronco Tube Dock installs directly to your dash, using existing mounting points. Installation requires no permanent modification to your Bronco. Typical install time is approximately 15 minutes. The Dock provides a clean solid mounting point for your Cell Phone, GPS, Spot Messenger, Flashlight, CB, CB Microphone, Radar Detector, Ham Radio, etc…
The Dock is manufactured in the USAusing hi-strength 1" diameter steel tubing. It comes standard in a durable, black wrinkle powder coat finish.
**Product images may display optional accessories, configurations, or finishes. The actual product may vary slightly from what is shown. If you have any questions regarding what is included with a product, please contact us
Works with 6th Generation Bronco Dash
