Value Oriented Sound System Upgrade(s) for 2025 Big Bend
DesertMike680
Las Vegas
Why do you say you don't get a sub? I thought subs have been standard on all trim levels starting in '23 (albeit with supply issues that had some factory sub-deletes with faux amp/spkr, like mine). Looking at Ford's build site the '25 base has listed under standard interior features "AM/FM Stereo with 7 Speakers including Subwoofer". Wouldn't be the first time build & price has been wrong, of course.
So, do all 2025's come with a sub then or is the build site lying?
Karl_in_Chicago
Karl
Chicago
I'm not really sure - would help if you could maybe cut and paste what you believe the lie to be. I simply cut and pasted from the build site that indicated a sub was part of the base, other than that I'm not following you.
GA2Dr
Marietta, GA
2024 Bronco 2 DR 2.7
Installed the trail seven kit today. I am very happy. Even without the amp it is a significant improvement over stock. I also Forscan'd (removed EQ, set all speakers to "speaker"). I suppose if you are a true audiophile this may not be enough but for me it is. 70 mph with the top back and it sounds great
