UPR Bronco Raptor Catch Can development! Lets GOOOO!!!
LethalPerformance
South Florida
www.lethalperformance.com
We just dropped off our brand new 2022 Bronco Raptor to UPR Products for them to development and test their catch can setups on. Steve the Catch Can man is working on it today and we should have the truck back tomorow. Stay tuned for a lot more info and content from us on this including part numbers, pricing, installation and a review.
LethalPerformance
LethalPerformance
South Florida
Steve at UPR just sent some pics over of the single valve setup that’s on our Braptor which came out great! He’s working on the dual valve setup today. I’ll make sure to update the thread once I get more pics.
Ford Bronco UPR Bronco Raptor Catch Can development! Lets GOOOO!!! 65CD0BD7-6468-4739-9B3F-8C2DC379CA28
Ford Bronco UPR Bronco Raptor Catch Can development! Lets GOOOO!!! C5FFD697-F159-44F1-9AF5-01E8C4B84701
LethalPerformance
LethalPerformance
South Florida
@LethalPerformance So happy you guys got your braptor.
So ready for these mods.
We'll be posting the links for the single valve setup today. I'll also be going down to UPR later this afternoon to check out the dual valve setup which we'll have listed shortly as well.
Let us know if you have any other questions in the meantime.
Thanks!
FellowM3
Northern NJ
Current: 22' Braptor, 2020 BMW M340
Thanks!
Might be a stupid question, but what is the difference between single valved and dual valved set ups?
LethalPerformance
LethalPerformance
South Florida
No question is a stupid question!
Single -> one source of vacuum; at idle it works best
Dual -> two sources of vacuum; works at idle and while driving as the source of vacuum is continuous (unlike single where, as you drive, drops to zero and there is no longer a vacuum)
It's one of those "better/best" situations where the single valve is good and works plenty for most but if you want -the best- it would be a dual valve can.
LethalPerformance
LethalPerformance
South Florida
The UPR Bronco Raptor dual valve catch cans are now live and available for purchase. This is the same one that they used our Braptor for to test and develop the kit. I haven't checked the can for oil yet but will follow up with a video once I get a moment to check on it.
In the meantime here's the link and some pics of it installed on our Braptor. If anyone has any questions feel free to reach out and we'll be glad to assist you.
https://www.lethalperformance.com/u...r-2022-bronco-raptor-3-0l-5030-284-1-css.html
Ford Bronco UPR Bronco Raptor Catch Can development! Lets GOOOO!!! ezgif.com-gif-maker (2)
Ford Bronco UPR Bronco Raptor Catch Can development! Lets GOOOO!!! ezgif.com-gif-maker (1)
Ford Bronco UPR Bronco Raptor Catch Can development! Lets GOOOO!!! ezgif.com-gif-maker (3)
FellowM3
Northern NJ
Can you give some feedback on the add-ons?
Mainly the billet pro check valve.
Hopefully a promo comes up soon for this. With all the options, $570 is a pretty penny
LethalPerformance
LethalPerformance
South Florida
We'll be releasing the video this afternoon which explains it all. However the check valve itself is there to prevent airflow while in boost from flowing back into the catch causing some oil mist to flow back into the PCV. The billet pro check valve is just a higher flowing valve which flows more air when under vacuum and has zero pressure leak back into the PCV under boost.
Stay tuned as the video will be posted.
Thanks!
orion
Jeremy
17' F-250, 17' Explorer
Do they have the dual for the 2.3L yet?
LethalPerformance
LethalPerformance
South Florida
I assume the dual valve requires drilling a hole here:
Yes. With the dual valve setup a hole needs to be drilled into the intake and you'll also need to remove that tricky fitting from the PCV using a pick tool.
Let us know if there's anything else we can help you with in the meantime.
Thanks!
LethalPerformance
LethalPerformance
South Florida
We don't have a dual valve option for the 2.3L at the moment. If we can get a vehicle over to UPR they will gladly develop one for us. Problem is that we don't own a 2.3L. Just a 2.7L and a 3.0L Braptor. If you know of anyone local to us or UPR give us a shout and we can arrange something.
Thanks!
LethalPerformance
LethalPerformance
South Florida
LethalPerformance
LethalPerformance
South Florida
Follow up video for this is being edited now. We put several thousand miles on our Bronco Raptor since the UPR dual valve catch can install as well as installed the JB4 tuner. My main point of doing this is that I often see people reply to threads about catch cans saying they're worthless and don't do anything or capture any oil. Well, wait till you see how well the UPR can works.
Stay tuned!
Ford Bronco UPR Bronco Raptor Catch Can development! Lets GOOOO!!! i-NrfRtXf-X3
