Uplifter switches no power
Drunknbroke11
Anthony
Pomona, CA
17 Ford FiST, 90 Lifted Ford E150, 51 Ford, 17
So I’m not getting power to auxiliary wires. Auxiliary switches do change color when toggled. Fuses are good and there is power to fuses. Any ideas on why there is no power to wires?
BUD
Boston
Lancia
Just to be clear, once you attach the wires in the bundle near fuses, you are not getting power at the other end?
projectbadlands
Robert
Los Angeles
2018 Colorado ZR2
If absolutely no wires are getting power, then its not an individual wire issue or a switch issue. It is pointing to the fuse box. I would remove the box and make sure harness is connected ok from and to the fuse box.
PWillette
Parrie
Maine
If the lights come on there is power to the switch. Did you check all of the aux wires w/ test meter w/ the switches on? Everything grounded properly?
Drunknbroke11
Drunknbroke11
Anthony
Pomona, CA
Correct
Drunknbroke11
Drunknbroke11
Anthony
Pomona, CA
Properly grounded. Testing with a meter to wires near master cylinder no power. I will remove fuse box and check connection of harness next.
Drunknbroke11
Drunknbroke11
Anthony
Pomona, CA
I do have the triple raptor lights piggybacked to fuse for swicth #5. They toggle off and on but still no power to wire end.
da_jokker
Jeep Wrangler JKUR
Wrong wire. If the toggle switch lights up when you flip it then you are good to go. Chances are your tapped into the wrong wire in the engine compartment... Ask me how I know.
There are two groups of terminated wires right next to each other and with the same colors.
One set goes to the toggle switches and received power when they're turned on. The other set goes to the various positions in the Bronco and are dead wires because they're just leads.
Once I wired to the correct colored version, my stuff worked.
Drunknbroke11
Drunknbroke11
Anthony
Pomona, CA
My pass through wires are not the same color as my powered wires. I have the same color coding as diagram above.
kodiakisland
Arkansas
So which wires exactly are you wired too and which wires exactly did you connect? Pictures at each junction or a good description would help. It’s hard to guess without a lot of details.
