Upgrades on the cheap
rayhil67
Ray
Douglassville pa
22 2dr Bronco, 06 hummer H3, 01 SuperDuty F250
So I thought I would create a post on a couple of mods I did on the cheap, but with great results. I know most fellow Bronco’ers spend close to $1000 on lights and $1500 + on audio upgrades, so I wanted to put a cheaper alternative out there. First I knew from reading post on here the audio was going to be my first priority, I went with 4 JVC DR series speakers/tweeters. The dash fit fine but due to size of tweeter I had to “hole saw” the stock grills in rollbar to get them to fit (see pic). Then for bass I got a boss powered sub, I picked this over the Kicker due to size, as us 2 door folks know we have limited space in back. As you can see from pic this fit like a glove with about 1/8 of a inch on both sides.
The results: excellent, Plenty of crisp sound from the 4” and good bass from the sub, tops off you can run volume around 18-20 and sounds great.
Cost: under $400 with all the connectors and what not. I did pay a pro $200 to do the sub cause well honestly, I got lazy and I wanted it done right, so total was 600
I really wanted the ford racing lights for the mirror pillars but could not bring myself to spend $450 on 2 lights, so I went to harbor freight and got there 3 inch lights instead. I also needed a light for the rear due to backing up my driveway so I did the 6 inch flood on top of the factory break light.
The results: Plenty of bright light both forward and aft, factory aux switches made this a breeze
Cost: under $200
I put a link to every thing bellow along with some pics if anybody’s cheap like me!!!!
https://www.crutchfield.com/S-2qSm5...wug=&msclkid=da06e90a422b188859158a269baa7d4c
https://www.amazon.com/Audio-Systems-BAB10-Amplified-Subwoofer/dp/B07MZT54N3?ref_=ast_sto_dp&th=1
https://www.harborfreight.com/3-in-led-flood-with-side-light-pair-57539.html
https://www.harborfreight.com/6-in-led-spot-light-57189.html
Ford Bronco Upgrades on the cheap Image1
Ford Bronco Upgrades on the cheap Image3
Ford Bronco Upgrades on the cheap Image2
Iamthedan1989
Dan
22' Bronco Base
Thanks for the cheap audio ideas!
Jdc
Jon
Massachusetts
Bronco Badlands
To each their own with their money but I it's hard to justify the need for $1000 lights unless you're out every weekend or racing.
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
I have done 34 mods and changes to my Bronco. 17 of them are under $100. It’s nice to have a vehicle that I can do things to that do not break the bank.
