ZROADZOFFICIAL
ZROADZOFFICIAL
ZROADZ
Corona
2022 Ford Bronco
will this work on the soft top AND hard top?
any quick disconnects being explored for taking down the soft top?
thanks.
We have a hard-top Bronco coming in next week for additional testing. As for disconnects no. Although the rack can be used for various load options, its initial design was for installing a tent which makes it a handful for disconnects.
Itchysquatch
Luke
Vermont
99 4runner, 2014 E class
@ZROADZOFFICIAL do you provide foam and or PPF to protect the paint in your kits? How about an install video (Iā€™ve searched around and couldnā€™t find one for the soft top)? Also the bronco6g code didnā€™t seem to work last I checked.
thanks, looks like a great product!
ZROADZOFFICIAL
ZROADZOFFICIAL
ZROADZ
Corona
2022 Ford Bronco
Any 2 door option in the works?
We have a 2dr Hardtop Rack on our site. Rack Only or With Lights too!
ZROADZOFFICIAL
ZROADZOFFICIAL
ZROADZ
Corona
2022 Ford Bronco
No video yet and there is a gasket included in the kit for the top edge of the 1/4 panel. Just checked the promo code and it's active. Use promo code BRONCO6G
ZROADZOFFICIAL
ZROADZOFFICIAL
ZROADZ
Corona
2022 Ford Bronco
Thank you for the feedback!
bajabronco57
Nor Cal
4Runner
Can't wait to hear if it works with the hard top.
Is it possible to disconnect at this point so that you can remove the rack and retain the light bar? That would allow for top less running while keeping the light bar attachment.
ZROADZOFFICIAL
ZROADZOFFICIAL
ZROADZ
Corona
2022 Ford Bronco
Technically you could. The issue is that the front bracket sits at the accessory portion of the windshield plus has an approx. extension of 6 inches that slips into the longitudianl bars and is held in place with a bolt
ZROADZOFFICIAL
ZROADZOFFICIAL
ZROADZ
Corona
2022 Ford Bronco
It would be way better if you can still open your soft top with this rack
Do you plan on installing a Roof top Tent? And if so how big/long??
ZROADZOFFICIAL
ZROADZOFFICIAL
ZROADZ
Corona
2022 Ford Bronco
Will this at least allow for the rear of the soft top to prop up?
We forgot to ask, did you plan on installing a Roof top Tent? And if so how big/long??
sLopeFx
FxA
Los Angeles, CA
22 Bronco BD Sas, 07 BMW 335i, 02 Cooper S JCW
Not planning on installing a roof top tent. The rear being able to open and prop up is a must. I already ordered the JCR soft top roof rack, but thanks for checking in. šŸ˜Ž
Itchysquatch
Luke
Vermont
@ZROADZOFFICIAL What are the dimensions of the cross bars (Looked on the website)? I have a yakima sky rise tent, and want to make sure it will fit. The feet only expand so far. Thanks in advance.
ZROADZOFFICIAL
ZROADZOFFICIAL
ZROADZ
Corona
2022 Ford Bronco
The front crossbar has an approx width of 3 inches while the rear crossbars are at 4". Both front and rear have multiple holes and slots as well that should accommodate almost ant accessory
