Update on failed 2.7 engine
dbeyers
Dan
Denver
Toyota Highlander
What he said. A new vehicle that blows the motor in under 2K miles sure sounds like the textbook definition of a lemon to me. Not only should your warranty be extended but you also should not be required ot make any payments during that time.
However if the vehicle is a lemon I personally would much prefer it be replaced in general versus a replacement motor which is subject to the skill set of said mechanic at given dealer and the break in procedure they adhere to, etc. etc.
Good luck and sorry.
Why are we taking fruit? Seems a pretty clear cut warranty issue.
Bronco21fan
Angelo
NewJersey
Yeah but the size of the oil pan would have zero impact on the intake/exhaust valves.
If you dig threw the million threads on hear there were some engineers that said the bronco 2.7 is a little differ t than the one in the f150 there not a complete match but pretty close
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
Are they not known to Ford? All OEM’s track things like this … and I wouldn’t expect them to post it here.
Any in-service mannequin failures would be reported to Ford. But as expected, Ford won't divulge that data. I'm expecting some of these mannequins to fail as they are sold to private buyers. They are all early builds and many were built with the 2.7L.
dbeyers
Dan
Denver
Toyota Highlander
True … I think I saw forum members reported 24 fails, out of 40,000 sold, that’s 0.06% … sound pretty isolated.
Obiwan
Southwest
Don't care to share personal info
You feel that a new vehicle with a blown motor that may ultimately take a 1/2 a year to get sorted out and back to them is "taking fruit"? What does that even mean and how does that apply to a case like this?
If he had this issue a year down the road or something along those lines that would be a warranty issue. A month or so is a reasonable time frame at most as well. An issue with a seat belt, warranty issue. An issue with a sensor, warranty issue. A basically BRAND NEW vehicle with a catastrophic engine failure and down for possibly a half a year?
We clearly have different ideas as to what is reasonable and what is not.
North7
North Texas
SUV
Huge bummer, though I appreciate the update.
Such an odd situation considering the 2.7L has been in the F-150 for YEARS and the F-150 is the best-selling vehicle they manufacture. You'd think this issues would have been solved long ago.
You sure about that?
Pretty sure the Bronco got the second gen 2.7L Nano EcoBoost. Which is the same 2.7L EcoBoost Ford puts in the F-150 starting back in 2018.
If it is a different engine... what's different?
Bronco 2.7 engine IS DIFFERENT from the F-150, different head and valve part numbers at a minimum.
So I did a little research when I got some time today. Here's some of what I cyphered:
Complete cyl head assy: ML3Z-6049-K LH, ML3Z-6049-J RH. no need to compare w/F150, you can see from the prefix those are Bronco only
Ex valve: JT4Z-6505-A
Valve spring: FT4Z-6513-A
Keeper: FT4Z-6518-A
Lock: FT4Z-6514-A
Rocker: FT4Z-6564-C
Lifter: BR3Z-6500-A
Got all those #s from repair link, thats when it got interesting...no intake valve listed! So I called my local parts dept that I buy from regularly. The guy I got i know I've talked to before, and is knowledgeable. Gave him the last 8 and asked for intake valve part #. 1st he asked me "this isn't one of those 2.7s that blew up is it?" Which I asked him "have u guys seen any of these?" He said "WE haven't, but I've heard about it" anyhow, his system didn't show a part # for an intake valve either...just an engineering #. The engineering # doesn't lead anywhere, but if he crosses it manually it comes back as FT4Z-6507-A.
The only PN I had him cross over to F150 was the exhaust valve, and they are the same, so the $64k question? Are the failed 2.7 valves all intakes? Don't know we will ever get a clear answer to that, but it sounds like they used a different intake valve and there was a manufacturing issue...heat treat etc. The service PN may be on hold till they decide how to address the issue...revert to previous parts, or trust the new intake valve manufacturer to fix the issue.
Mpatient1
Mel
FLORIDA
'22 BD CO/MID, 2006 mustang pony package
they don't want to ship an engine for fear it will blow too, but continue to put them in new Broncos.... something about that logic sure doesn't track.
Snowdogyyz
23 Ford Bronco Wildtrak
It’s not 24 out of total 2.7’s sold. It’s 24 out of how many 2.7’s are owned by people on this forum. I have no idea what that number is but I know it’s not 40k!
Daktari
Oliver
3240 miles on mine, no issues so far. I'll worry about mine if/when it blows, no time for conspiracies and paranoia.
Good luck to the OP, I hope they get that situation sorted out and pop a new engine in your rig pronto! Holidays might have slowed things down a bit, but we're almost 2 weeks past that, some communication and clarification is certainly to be expected by now. Good luck!
Firefight911
Phil
Simpsonville, South Carolina
2022 Ford Bronco 4-door Wildtrak, Eruption Green
You have heard of Dirt Mountain......no?
dbeyers
Dan
Denver
Toyota Highlander
Sorry talking fruit … lemon law. I would think it’s very warrantable - the sooner the better - as far as the timing to get it fixed … Covid??? Getting a replacement vehicle - good luck with that any time soon. Obviously 6 month downtime is ridiculous.
dbeyers
Dan
Denver
Toyota Highlander
True - or 0.06% of Bronco engines sold.
Essmith94
Edward
Fort Worth, Texas
GMC Sierra
So I have a 2.7 built on 21224 and approaching 1700 miles…. Now I am going to be worried every time I start the Bronco. 🙄😫
Seriously, any preventive checking I can do to possibly head off a failure? Really like my Bronco and don’t want to have it sit for 6 months waiting on a new motor.
Scottpyro
Carlsbad California
2021 bronco 1970 bronco 2006 tiger rv 2006 gmc tru
what are the engine # indicated on valve cover range of suspect bad valve motors? Thx.
NC_Pinz
Central NC
It has not been conclusively determined. There is another thread that gives the current build date range. Do a search and it should be easy to find. The count is up to 33 so far on the site.
