Update from software update Ford power-up 1.6.0
Qasimateen
Qasim
Rancho Cucamonga, CA
Ford expedition
I am going through this forum and can see that people are on versions higher than 2.0. I checked my 2021 outer banks bronco with the 12 inch display and it says I am at 1.6.0 and that it is up to date.
How come people are able to update theirs but mine is still on an older version and says that it’s the most up to date version? I am connected to the wifi and have set a recurring schedule for the update.
Ford Bronco Update from software update Ford power-up 1.6.0 38356959-FD1F-476C-8F2E-97C5EA02A8FF
Jae
Josh
Des Moines, IA
Looks like this is an old problem that doesn't have a solution. I am in the same boat with being stuck on version 1.6 and no way to update. Everything is setup for updates--WiFi, auto update, and scheduling. When in the vehicle it says everything is up to date.
Any help on this would be appreciated.
Ducati1098
Bring it to a dealer and tell them your OTA updates aren’t working. If there is no OTA history then there is a programming issue preventing it. They will probably need to manually update your GWM and TCU, then OTA updates should start to work again.
  • Like
Reactions: Cat
Jae
Josh
Des Moines, IA
Not to be disparaging of my dealer, but I gave them a call and they suggested I disengage the battery for 10 minutes and see if that corrects. I intend to do that, but if it doesn't work can you break down those acronyms in case they are not familiar?
Ducati1098
OTA= Over the air
TCU= Telematics control unit
GWM= Gateway module
Ninjak
Miami
Updates are sometimes delivered regionally. I am not sure of Ford's schedule, but being in the bizz, I do know this is how large-scaled updates can be done.
Ducati1098
Correct, not all vehicles will get updates at the same time because they roll updates out.
However, being stuck at 1.6.0 is indication of an issue. Every Bronco should be far passed that. I'd be willing to bet it was delivered with 1.6.0 and has never had an update.
Jae
Josh
Des Moines, IA
tdiddy
Tommy
Illinois
2010 Ford F150, 2012 Ford Focus
I'm in this exact same situation. I have a dealer service scheduled for this Friday and I told them I want the Ford Power-Up Software updated. We will see how this goes.
Ford Bronco Update from software update Ford power-up 1.6.0 1000001659
Ford Bronco Update from software update Ford power-up 1.6.0 1000001658
MN_OuterBanks
AW
Minnesota
2015 F150 SuperCrew
I haven’t been updated since this:
I have auto updates on and everything looks right. I wish there was a way to know what version you SHOULD be on. I haven’t been updated since February.
Ford Bronco Update from software update Ford power-up 1.6.0 IMG_9141
pakrat
JG
Lake Tahoe
Toyota 4Runner-F250-Tundra
Somewhere on B6G someone suggested to set a specific time overnight to check for updates instead of just leaving on automatic updates or trying to manually update. I set mine to check for updates at 2 AM. Can't remember if I set a specific day of the week as well or even if you can do that but for some reason Tuesdays stick in my head. For sure the specific time though.
I wasn't getting them either on my '21 until I did this. Now it is always current within a week.
Blancobg6
Rafael
Richmond, VA
2021 OB 4DR
Sharing my service doc in case this helps someone in the future, same issue but finally fixed
Ford Bronco Update from software update Ford power-up 1.6.0 IMG_0037
mcinfantry
Lee
Louisiana
Badlands 2 door
I forced ALL of mine since ive owned it With FDRS
Ford Bronco Update from software update Ford power-up 1.6.0 IMG_4828
…. And today….
gonyr
NY
Thanks so much for this. Maybe I can finally convince someone there's an issue.
Blancobg6
Rafael
Richmond, VA
2021 OB 4DR
Took me 2 dealers and 3 trips
