Tuffy vault installed
Ape Factory
Michel
Audi RS5/Ford F150/Infiniti QX70S
In addition to cleaning and driving around sans top for the first time today, I installed a Tuffy console vault. The installation is relatively straightforward with no real gotchas other than the proximity of the bottom screws to the side of the console. They would have been much better off going with Allen head screws as opposed to Philips screws. It's sort of a pain to get them threaded and then tighten with a normal screwdriver as they're millimeters off the side of the console.
I went with the Tuffy for three reasons. First, it has a larger opening than the Ford-branded version and two, the full length piano hinge is far beefier than the eBay/Amazon Chinese specials. Third, it's made in the USA.
I went with the code version and I have a "routine" that's faster than pulling keys out of my pocket. It's JUST large enough for an LTT PX4 compact carry with comp and an EPS RDO. The flush 15 round mag fits, extended mags do not. I plan on a semi permanent holster setup so the grip is pointed up. As is, it's wedged in there so it doesn't really move around. To me, this setup beats something like a Vaultek which I've been using for the past year.
Anyway, there's really no side to side play. The Tuffy has "wings" which get installed after you wedge the main body into the console.
It's a squeeze but it'll work for now.
Ford Bronco Tuffy vault installed IMG_7418
Ford Bronco Tuffy vault installed IMG_7414
Ford Bronco Tuffy vault installed IMG_7433
Ford Bronco Tuffy vault installed IMG_7430
Ford Bronco Tuffy vault installed 699461-f603c3fb321859c0bb7e6e8caa2de641
Ford Bronco Tuffy vault installed 699459-d605e3a0fc8f7706e8cda499c05fdbd
Ford Bronco Tuffy vault installed 699462-ff2fb31c8bfd13d33a4e67070c0b2d1
Ford Bronco Tuffy vault installed 699463-bc817234a9e0923bf3521a87120fda75
Syndister
Cindy
Ft. Lauderdale, FL
'18 Harley Road King Special, '23 Bronc
Is it deep enough to mount a holster to the side?
~ Asking for a friend (my Glock 43 is my friend)
Ape Factory
Ape Factory
Michel
Yes, it should be. I can stand the gun on end and the lid will close. I may design something that stands the gun upright, in a holster, with one mag holder as well, along with an additional cubby to hold miscellaneous items.
I can measure the depth when I get home and let you know 100% for sure.
