Trail Seven - Self-powered Kicker 12" Solo-Baric Kit Install
Chapito
Laredo, TX
2023 Bronco Wildtrak
I wanted to share my experience installing the Trail Seven Kicker 12" Powered Subwoofer kit. In my mind, this is an "almost perfect" plug-and-play solution.
Installation Details:
  • Power: The kit includes pre-cut and terminated power/ground wiring. I opted for the optional fuse mount, which is very sturdy and utilizes an existing bolt by the battery for a clean mount. I routed the power cable through the factory firewall grommet.
  • Signal: The kit comes with T-taps to pull signal from the driver-side kick panel, but I’m not a fan of tapping factory wires. Instead, I used a Bronco-specific speaker harness and soldered it to the included RCA harness for a 100% PNP setup.
  • Control: I mounted the bass knob directly under the steering wheel, which makes it easy to adjust the levels on the fly.
Performance: The enclosure is on the larger side and does eat up some cargo space, but the jump in bass makes it a worthy trade-off for me. A huge plus is the auto-sensing turn-on so there was no need to run a remote wire and the ability to use the existing speaker signal so there is no need separate low line converter.
Overall Impression: This sub is a great addition to the existing B&O system, which definitely lacks low-end power from the factory.
RideClimbNJ
NJ
23Wildtrak
I was looking at this. Can you send a pic of where you mounted it?
EOD98
Las Vegas
2025 Bronco Badlands Sasquatch
I don’t think this is a mounted sub. Just sits in the back cargo area
RideClimbNJ
NJ
23Wildtrak
Oh interesting. Just sits on the carpet? I guess you can unplug it and take out if you needed the cargo room.
23OBX2.7
AB Canada
2023 Bronco
Can easily tailgate mount any shallow sub with couple solod metal brackets and rivnuts.
