TPMS Calibration?
DALOLA
Retired
Ohio 🇺🇸
'24 Mach-E, '22 Maverick, Hot Rods
Does anyone know if the OEM TPMS sensors can be calibrated to read correct pressures? Mine are reading ~5psi low, which sucks because I'm running my OEM 35's at ~35psi, and because the sensors are not accurate, it's throwing a low pressure light. I hate running around with warning lights, especially when they are false.
Good question. I know you can adjust the pressure the light comes on at with Forscan - not sure about calibrating the sensors to read accurately though.
Watching to see if someone can answer the question.
SoDak1623
Cole
South Dakota
1996 F150, 2022 Badlands MT
Mine are also off, they all display 2 psi lower than a manual gauge.
Jdyount
Kansas
2021 Badlands
