Towing - 7 Pin harness options
da_jokker
Jeep Wrangler JKUR
I got an universal 7 pin conversation kit. Tied into the trailer brake access plug under the driver side dash. The plug has power, ground, brake petal switch input and output to trailer brake. I used the Curt 4 way to get my lights. The universals 7 pin kit has a receiver that accepts the 4 way plug. I’ll try and post some pics. But it was pretty easy to do.
So I recently added my tow package back, but if it is this easy, it sounds very promising for many.
One would think, if you could pick up all the necessary wires (minus the curt 4-pin taps) then someone just needs to make a piggyback adapter for the brake controller plug, similar to the ones made for that Kicker 200.4 install.
Here's a great opportunity for some of the vendors to package this all up.
Braaap
Outback
jbryant
Jimmy
Indianapolis
Ford Raptor
You’re right. There’s a connector under the dash to the right of the drivers knee. If a vendor could made a connector we’d all be set for a 7 pin set up!
Nng23b
2022 Bronco
This connector is different from the factory when the tow package is included, right?
jbryant
Jimmy
Indianapolis
Ford Raptor
Nope, it’s the same. The brake signal wire feeds into the connection. It’s the same connector that Ford recommended brake controller plugs into.
NVCowboy
William
Henderson, NV
A deep dive into the towing forums will reveal a thread where forum members found a wiring harness under the driver’s side rear trunk trim panel. I believe it is the harness used for the factory charge circuit.
Edit: the best 7 pin discussion is at
https://www.bronco6g.com/forum/threads/tow-package-arrived-contents-inside.17659/
It starts out discussing the receiver but evolves into installing a 7 pin plug. The thread has pictures and diagrams. The thread probably needs a sticky because it’s really informative an documents “Flip’s” work on this topic.
da_jokker
Jeep Wrangler JKUR
Of all the towing threads I follow, that one I typically ignore because I don't care what's was in that guy's box and When I initially looked at it, it was just a four-pin setup which solved nothing.
Now that you've said that it involved into a seven-pin discussion, I'll have to pay more attention!
NVCowboy
William
Henderson, NV
The first hint of the good stuff begins page 6, followed by more BS until pages 9 and 10 where it really gets rolling.
