Torx and Torx Plus question
Bt_ostate
Oklahoma/Colorado
2021 Ranger Tremor 2021 Bronco 4-Door FE
Koz44
Alex
Westchester County NY
2 Door Bronco Outer Banks
Two regular Torx bits in my kit. The smaller of the two worked fine on the bolts to my hardtop (so not torx+). The larger of the two appeared to fit the bolts for the modular bumper but did not - needed the torx+.
If you have a hardtop or plan on having one you will need at least one regular torx and one torx+ bit.
Herbie
Alex
Cleveland OH
2022 Badlands
Do you realize that there is really no useful info in all those pages? Some of us just want to know if every Fastener is Tp! For example, the rock rails?
I was just trying to be helpful to those asking some questions and you are just being rude.
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
Is there a significant advantage of Torx+? Assume it must be in the assembly process? It’s a PITA. Sort of like JIS or Posi screws. I just ordered a set 😕
Garemlin
Delaware
Boggles the mind why they use these Torx+ fasteners, and really built them up on the modularity level. But they don't even include the bits to remove them.
Silver-Bolt
Eureka, MT
On the larger diameter fasteners you can visually see the difference. On the smaller fasteners it is a little tougher. You can use a Torx bit in a Torx-Plus fastener. However you cannot use a Torx-Plus in a Torx fastener. Here is a good explanation.
How the TORX PLUS Drive Works
Ford Bronco Torx and Torx Plus question 3dtorxplus
Unique, elliptically-based geometric configuration
maximizes engagement between driver and fastener
True 0° drive angle virtually eliminates the radial forces that cause stress on fastener recesses with vertical walls
  • Allows increased seating torques while retaining current bit life spans
Large cross-sectional areas at lobes to maximize torque transfer and increase torsional strength
Higher torque removal capability than any other drive system
  • Helps minimize damage to boss during removal and reinsertion of the screw
Ford Bronco Torx and Torx Plus question sidewalls
Vertical sidewalls
completely enclose the driver tip, reducing tool slippage and virtually eliminating camout
  • Prevents damage to the fastener and surrounding surfaces, which often occurs with cross recess fasteners
  • Eliminates the debris camout can create, which can damage sensitive applications
TORX Drive TORX PLUS Drive
Improved fit between fastener and tool minimizes wear on the drive bit
  • Drive bit life lengthened up to 12 times
  • Downtime and costs are reduced since significantly fewer drive bit changes are required
Compatible with TORX® Drive for field service (internal recess only)
  • Allows field service personnel to use existing TORX tools
  • In order to fully realize the assembly line benefits of the TORX PLUS design, TORX PLUS tooling is required
Ford Bronco Torx and Torx Plus question torx_vs_torxplus
Bababue
Tom
Pa
2014 Ford F-250 lariat
These just came in the mail today lol
USA made* (y)
*Amazon description says made in China. Amazon description is wrong.
When I clicked through your link and looked at them it says “country of origin: China “.
GToddC5
Todd
South Jersey
www.bronco6g.com
I also bought the set from Amazon, and a quick walk around the vehicle for obvious fasteners (Bumpers, MIC top, and 2 different sizes at the mounted side mirror locations) all fit nice and snug. So at least four different sizes from that kit are relevant. I haven't checked underneath yet, but I'm sure the kit will cover whatever is under there. It's affordable, and a tool set I didn't have.
TX-Hans
Any one have a list of what size Torx plus bits are needed for the Bronco?
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
My order is in thanks for the great info here.
Headsong
Actually, I was just trying to get an answer, like many, many others, which weren't answered until just above. I've followed those 7 pages for naught as just about every OTHER answer was given other than what we need! lol So I was merely pointing out that that was one of those useless threads....but that's what we're here for! Sorry I seemed rude.
Ksjrb03
Tx
F250
Get the set. Ive used 25, 27, 30 and 40 so far. If you own a Bronco you need a Torx+ bit set, unless your a take it to the shop kinda guy.
