- Ben
- Jul 15, 2020
- 21
- 851
- 2,692
- Baltimore, MD
- 2023 Bronco Raptor
- Raptor
The company did get back to me fairly quickly and said they’re working with the manufacturer of the boxes to make a heavier duty box and they will send me one once they have them produced.
After assembling here’s my impression:
The unit is solid and the operation appears to be pretty simple. Setting it up for the Bronco will be easy and adjusting it for my daughter’s JKU will be easy as well.
I’m missing a pin for the leg and a set screw for the forward arm, which is a bit frustrating. I contacted them about this as well and I’m waiting for a response.
As far as it being marketed as portable, that’s a big stretch. You need to just about fully disassemble the thing to get it to fit in the travel boxes. It’s not a quick/simple process to just whip out of the back of the Bronco, put a couple of pins in, and start lifting the top off. It’s just not reasonable to expect to travel with this thing, hop out and have the top off in 5 minutes. It can probably be modified with quick release pins replacing the bolts but that was not something I was expecting to have to do after spending $900. I didn’t buy it intending to travel with it but I did plan to keep it in its storage boxes in the off-season.
I do intend to break it down in the off-season but I was expecting a much faster process to do that. Not a huge deal I guess, just kind of shady marketing. The footprint can be fairly small and I like the pedal lift vs the lift bar.
I’ll probably use it to remove my top when it’s nicer next week and see how the actual use goes.
