Tools needed for hardtop or door removal?
sliwa
Matthew
Ford Focus
I searched, but didn’t find what I was looking for.
Both hard tops feature tool-free removal, correct? And the doors require a bolt to be removed? Is Ford providing a tool kit?
I noticed the engine bay is lacking space and tie downs for a tool box like my ‘84 Bronco had...
SamG
Sam
Detroit Area
sas
I'd wager if tools are required its nothing more than a screw driver or allen key.
99% chance those would be supplied
FourHorses
Four Ford Horses and an Expedition
I guessing that may be part of the 200 accessories. At least a small Bronco labeled tool pouch with the specific simple tools for the rig. Along with a first aid kid. Possibly attachable to the MOLLE panel on the back seats or on the rear trunk deck.
sliwa
sliwa
Matthew
Ford Focus
Yeah, I’m assuming whatever needed will be supplied.
Not that many carry around an allan wrench, but I hope it’s at least some type of security bit. With as light and easy to remove as they are reported to be, I don’t want someone walking off with a door because they have a screwdriver in their pocketknife.
BroncoKong Jr.
Andrew
All of the "Bronco bolts" that they've shown are Torx.
Hoofnmouth
mark
N ca
ford focus st
Thats not nice calling them tools i am grateful for all the help lifting that heavy top?
Megawatt
JO
Where the asphalt melts in the Summer
Lifted Rubicon usually off-road.
I don’t see a visible hinge on the outside. Looks like the door must be opened first to get to the M10 bolt that must be removed. So as long as your door is locked I doubt you come back to stolen doors because some thief was walking around with the tool to remove doors.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
This is what came with my Wrangler and is all that is needed to remove the doors and hard top clam shell. (Panels over the front doors are removable by hand.)
I imagine Bronco will be something similar.
For reference that ratchet is only about 4-5” long.
Ford Bronco Tools needed for hardtop or door removal? UUI_82214166AB_1485836601404
Hey19
JJ
Bethlehem
I remember hearing or reading one 10mm fastener and a connector to remove the door. With all the hype about easily removable doors I’m sure a tool of some kind will be provided. I would also guess you could get a better tool than what the factory supplies, I wouldn’t count on it being the highest quality.
Stitches1974
SW Florida
2019 Dodge Challenger Scat Pack
The factory set that came with my Wrangler, as posted above, seemed to be of very good quality.
It was 2 bolts for each door and 1 connector and the door was off. There was even a holder for the bolts in the cargo area, so you didn't misplace them.
