Tmat Cargo Management System
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
We're happy to announce that we now stock the Tmat Cargo Management System. We picked this up for one of our trucks, loved it so much we signed on as a dealer and immediately started to stock the product. We actually decided that since we specialize in Broncos that we'd put together 2 kits for the Broncos (2 Door and 4 Door)
Tmat’s truck bed mat is the ultimate in truck bed organization. Cargo blockers plug into the mat to divide your truck bed into unique compartments around your tools and equipment. By installing Tmat between the wheel wells, the mat can slide across your truck bed and onto your tailgate for easier access to cargo. Tmat can also be customized to install around wheel wells, onto drawer systems, bed slides, or even a sheet of OSB with rollers.
Tmat Management System for the 2021+ Ford Bronco (4 Door) measures 42" wide by 30" deep fully assembled and fits great in the rear of the 4 Door Bronco This cargo management system can easily be modified to your own specifications. The blockers simply plug into the mat in any configuration to hold your tools, equipment, and small cargo in place during transit. By hindering movement, items sit securely without rolling or moving during transportation. Please note that since these are 12x12 and 12x2 panels there will be areas of the rear that the Tmat system are not installed on. The Tmat Management System for the 2021+ Ford Bronco (2 Door) measures 42" wide by 22" deep fully assembled.
Tmat Cargo Management System for 2021+ Ford Bronco (2 Door)
https://www.4x4truckleds.com/tmat-cargo-management-system-for-2021-ford-bronco-2-door/
Tmat Cargo Management System for 2021+ Ford Bronco (4 Door)
https://www.4x4truckleds.com/tmat-cargo-management-system-for-2021-ford-bronco-4-door/
Ford Bronco Tmat Cargo Management System Bronco1
Ford Bronco Tmat Cargo Management System Bronco2
Ford Bronco Tmat Cargo Management System Bronco3
Ford Bronco Tmat Cargo Management System Bronco4
mack092
mack
Houston
ford bronco
I was considering this. Question is what ties the mat to the cargo area floor?
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Nothing. No need for it to be attached to the floor. It's not going anywhere. It fits in the space.
