Door Panel Cargo Nets
wrbix
VA and FL
LR Def90, F250 7.3, Caterham 7, LR Series III, etc
What if you had a non slip rubberized coating over it instead of powder coat? It would not only add a buffer for the edges, help prevent bottles from moving/clanking as much as it would act as a little bit of a shock absorber.
The same type of coating they put over storage hooks, etc.
I agree with the previous poster, the product itself looks awesome but the bumper detracts greatly from it.
Edit to add, photo for clarification:
DIY PlastiDip or Flex Seal in rattle can…..PlastiDip comes in colors too.
TheShark
I have to say that when I first ordered them I wondered about being all metal if that would be an issue but honestly I don't find any problem. I can't say my legs ever really touch them even when the door is closed.
Skip
Skip
Sweet Home Alabama
2020 Ford Edge, 2024 Holiday Rambler
Got mine installed last night. They fit great, don't touch my legs, hold a water bottle easily. I re-installed the bungie back in for a divider. Thanks for a great designed product.
section525
Red Bluff CA
1975 Bronco
The rear set will be offered separately from the front set. Price point will be roughly the same as the front doors. Keep in mind that these will not be as simple to install as the front pockets.
Sneak peek yet? :D
Mountains2Metal
Mountains2Metal
Nick
Eastern, NC
2012 F-150, 67 Bronco, 94 Range Rover
Sneak peek yet? :D
Here is one on my Bronco now. I am making a couple minor changes. Overall the look will be the same. I've gotten several requests about the back doors after the good feedback on the fronts. I want to make sure it is right before we get this out the door.
Ford Bronco Door Panel Cargo Nets 20211223_103248
LVKnight
Jay
Henderson, NV
Jetta GLI
Just ordered them tonight for my badlands. Definitely interested in them for the back as well.
Max778
Max
Toyota Coupe
Wow Those Are awesome..
abdickson70
Adam
Eagle Mountain, UT
BMW
Changed the color on mine and installed them yesterday. Have to say these are a great product and very useful in getting some extra storage space.
Did you sand the powder coat, prime, paint and clear? How is it adhering? Thanks!
OddBall88
Joseph
Ford Bronco
Just used some plastidip to see if I actually liked it or not and so far it’s held up well enough. Might do something more permanent later but not sure yet.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Anyone install theirs and saved the driver side trim piece (not the net itself) and are willing to part with it?
leby065
Chicago
Infiniti FX35
Following to see if the doors fit in the back. Figure I can remove them quickly if needed but curious if anyone tried it.
Mountains2Metal
Mountains2Metal
Nick
Eastern, NC
The rear door pockets are live now. These are a match to the front door pockets. Went with a PEM stud instead of bolts since the stock rear door pockets didn't have bolts. You can reuse the stock bungee as well.
https://mountains2metal.com/product/br6dpmr/
Intall Video:
Michael Grasso
Indianapolis
2025 Ford Bronco
HorizonHunter
Joseph
Chapel Hill, NC
Grand Cherokee Trailhawk
Has anyone mounted a quick fist on the diagonal of these? Thinking flashlights, umbrellas, element extinguishers.
