Tire Recommendations - 285/70r17
Laurensimms7
Lauren
Norfolk, VA
2016 Ford Fusion Titanium
Hey All,
I have read through SO many threads and websites and still am just not understanding what type of tire to go with. I am confused when it comes to load range? Ply?? C, D, E????
Heres what I am looking for, maybe you all can help me out:
285/70r17. Something that looks good. Ill be driving this as my daily, and will be on road 90% of the time, but want the ability to go on light trails when needed.
*Edit to add: I have 4 door OBX on order arriving in Sept
derichio02
Bo
Southern California
Bronco Badlands, Maverick, Tesla M3, F250 Tremor
I have these on my wife's OBX, You will lose some mpg's but they ride great on pavement and trails, Load Range C. I also have this same tire in a 35" for my Wildtrak
https://www.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&tireModel=All-Terrain+T/A+KO2&partnum=87SR7KO2V2&vehicleSearch=false&fromCompare1=yes
Ford Bronco Tire Recommendations - 285/70r17 1661385102575
You can think of ply/load range as how many "layers" the tire has. The higher the "layers" the stiffer the tire and the less bumps it will absorb(bouncy ride). Load Range C is good for the Bronco unless you are doing extreme rock crawling. Here is a good article
https://www.americastire.com/learn/load-range-load-index?storeCode=1043
derichio02
Bo
Southern California
Also the OBX comes stock with 18" wheels right? If so you may want to look into a 285/65/18 if you are planning on keeping the stock wheels.
dbattle
Northern VA
2011 Toyota Prius
Laurensimms7
Laurensimms7
Lauren
Norfolk, VA
This was super helpful- thank you so much
Danny's Bronco
Danny
Indian Rocks Beach
Shoes! Waiting for that 2 door to ship!
Laurensimms7
Laurensimms7
Lauren
Norfolk, VA
I have actually decided to go with the 17in Icon Compression wheels in Bronze with a +25 offset. Hoping it all works out lol
Laurensimms7
Laurensimms7
Lauren
Norfolk, VA
derichio02
Bo
Southern California
Whats the width of the wheel?
I went with 17x8 +18 and 285/70/17. No lift, Zero rubbing and crash bars in place. Here is a pic
Ford Bronco Tire Recommendations - 285/70r17 IMG_5141
mikedege
Poway, Ca
Ford Maverick, Ford Bronco
When I chose my upgrade to 285/70/17, I had to have "C" or "SL(standard load)" because I wanted the tire most suited for daily driving. "E" load I had on my last truck and it was extra bumpy, I didn't enjoy the day to day driving.
I ended up choosing the Toyo Open Country AT3 and really love them. BFG's are another great choice. As well as the Falken Wildpeaks. Those were my top 3. I ended up choosing the Toyos mostly because I had the BFGs in the past, and wanted to try something new. So far, they are great tires. I think out of those 3, you cant go wrong. imo....
Good luck,
Laurensimms7
Laurensimms7
Lauren
Norfolk, VA
Good luck,
Awesome, this gives me a jumping off point. I was seeing lots of recommendations for the Nitto Ridge Grapplers, Toyo Open Country AT3, and the Falken Wildpeaks!
Laurensimms7
Laurensimms7
Lauren
Norfolk, VA
Oh cool, they should fit great. The poke will be 0.7mm more than what you see on my OBX I uploaded aka not bad but def a more aggressive stance
Yours looks great- if its too much I guess I can always order sas flares!
83XLT
Carl
Cincinnati
22 EG Big Bend 2.7
If you're weight conscious, check the weight of the tires you want before you buy...I almost bought the Wildpeaks but they are 15# more than some of the other popular tires at the same size (285/70/17). It's not just extra weight on your ride, it's weight on the axle that your engine has to rotate.
