Tire cover camera hole
Elekktrik
Bronco Badlands 2023
Hey All,
Looking for some advice. I just got a spare tire cover with a camera hole and it is centered around the camera, however the hole is bigger than the camera. Are there any ring inserts available to tighten this down on the camera module?
Ford Bronco Tire cover camera hole IMG_3722
Ford Bronco Tire cover camera hole IMG_3723
zone23
Youngstown, Ohio
2022 Ford Bronco
They do make them as mine has it.
Ford Bronco Tire cover camera hole IMG_1116
HotLap
Bradley
CA Central Coast
2023 Bronco, 2024 HD Street Glide & 2019 Yamaha XSR900
Awe man...Zone23 you had to post that...my EXACT OBX that's awaiting production...
Apologies OP, no help I know...
Swallace
Sean
N. Andover Ma
Toyota ,Gmc and Subaru
Hey All,
Go to home Depot and pick up a 2 inch pipe gasket. this should fit perfict around the camera and the wider base should fill the gap.
Murraydog11
Rick
2021 2Dr Outer Banks, Jeep Cherokee
Mine came with one. Although the hole in yours is much larger...
Ford Bronco Tire cover camera hole 20220702_112850 (3)
Billy Goat
Pete
Fort Worth
2022 Bronco Velociraptor 400
I did the pipe gasket from Home Depot, used a belt sander to trim it down and cut a slice to fit​
Ford Bronco Tire cover camera hole 16845948214162823048263892033255
Ford Bronco Tire cover camera hole 16845948556627832607812630939408
Headsong
Viagra?
(Sorry, too easy.)
fourdayoff
Boulder City Nv
2022 Bronco Badlands/sasquatch 2.7
I would leave it for ventilation, Here in the southwest tires bake inside those covers, most tire dealers here don't recommend them. Jim.
Wildryd
Jason
2021 Ford F150 Rocky Ridge, 2016 Shelby GT-H
Where did you get this cover and do they make them for 37's?
Elekktrik
Elekktrik
Billy Goat
Pete
Fort Worth
Got it at Tirecovers com ( what a generic name but it works) Many different designs and values for selection of said designs. As I recall I had to do a little pencil work to figure out what would work for me because their size chart isn't as exact as you'd like and man was it a tight fit. Don't hold me to it but I think you can custom order as well.
