Tick noise from rear
AZ23
Andrew
Grosse Pointe Woods, Michigan
2022 Bronco Badlands 4DR, 2018 Focus Hatch
I just recently joined as a forum member but have been reading threads for a long time. Took delivery of my 2.7L badlands a few weeks ago and haven’t had the chance to put many miles on it yet. I’ve noticed that there’s kind of a tick noise from the rear between 35-45mph and it dies out either before lower than 35 or over 45. Noticeable with the windows down forsure so I know it’s something on the exterior rather than an interior rattle. Can’t place the noise particularly well to tell what exactly it’s coming from. I haven’t seen this in any other threads yet so seeing if someone else out there is experiencing a similar issue. Maybe it’s something that will go away after I put miles on it / finish the “break in period”. I may take a video and post at some point as well
GiddyUp82
Ann
Ford Bronco
Did you ever find what was causing the ticking sound? I have a 2023 2.7L Badlands also and it does the same exact thing. I have an appointment with dealer mid July
AZ23
AZ23
Andrew
Hello, yes I ended up taking it to the dealer and they realigned the backing plate, that made the noise go away. Misalignment must have been causing there to be something tapping together. They had a FSE (Field service engineer) from Ford diagnose it. Not sure if your problem is similar but asking the dealer to take a look or an FSE would be a good start. It was covered under warranty as well.
GiddyUp82
Ann
Ford Bronco
Thanks so much!
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hey there. I can look into your Bronco’s noise concerns on my end if you’d like. Will you send us a private message with your VIN and dealership info?
helifino16
Ron
Mount Sinai, NY (Long Island)
What IS that noise?
Sometimes you get it fixed...
Sometimes, you find it's something else:
Ford Bronco Tick noise from rear 1687545156023
(tick, tick, tick)
