TEXAS SNOW DAY
Ryuk
PA
2021 Ford Ranger, 2023 Ford F-150
Today in PA we have gotten 10" of snow and it has turned to sleet. Our Homes are setup for this though, so it's no big deal.
Texas is one of those areas that seems to constantly get hammered by Mother Nature.
Katrina, Rita, to name 2 huge storms but more in between then and now and now this.
flatlander40
House in my neighborhood that had a busted pipe.
That’s tough. I’m sure drywall and many of the construction materials will be tough to find and carpenters/plumbers will be overextended.
flatlander40
I don’t know for a fact, but it is my understanding that us Texans have higher insurance rates than most, due to our extreme weather.
j_marinelli
Spring Branch, TX.
Its a POS, will only run intermittently. I need to take it part and find out why.
Got it here <-
Mine ( I mean my kids) was doing the same thing on the snow.
Ford Bronco TEXAS SNOW DAY 20210215_153028
Not going to lie. Might be pushing it to the limits to kill it so I can transplant body to better chassis.
Ryuk
PA
It would make sense due to how often you need it.
BlueBronco
DFW
After two days of no hot water I thawed out my tankless water heater uninsulated inlet valve with a floor heater. Now we Texans learn about heater wrap cords.
Is your tankless water heater seriously on the outside of your house?? Who thought that was a good idea and I am surprised that it is allowed by building code. Although, looking at the exhaust, that model is most certainly not made to be installed inside. I installed mine right next to my gas furnace. The first one I bought required stainless steel duct for the intake/exhaust but I quickly returned that one and found one where I could use schedule 40 pvc pipe instead.
Hossamus Prime
Arkansas
www.instagram.com
21 BadSquatch,‘21 ExplorerST , RIP 84 & 90 Broncos
Does yours cut in out? I can't get mine to drive more than 10 seconds, need to take it apart.
j_marinelli
Spring Branch, TX.
As soon as I got it in the snow it would cut out. After about 10 mins of trying, I brought it inside to completely drive out. Haven't tried it since to see if the cut out still persists.
North7
North Texas
SUV
Yes, with our building boom in the northern cities, north and south of the 380, this is standard practice now. I'm sure the building code departments said, "if power plants and water facilities don't need to winterize, why should homeowners?". 🤷‍♂️
So you can see in the photo below I added some insulation to the uninsulated valves. Next, I'm ordering one of the Automatic Electric Heat Cables and some Foam Pipe Wrap Insulation Tape to wrap the valves and pipes in the cabinet.
Ford Bronco TEXAS SNOW DAY 20210218_092336
Ford Bronco TEXAS SNOW DAY 81B1z5qz52L._AC_SL1500_
pan-y-cerveza
Manitoba
Tacoma Pro
I haven't looked at the numbers yet but it looks like parts of Texas have had more snow this week than I have had here in Manitoba all winter. It's been a strange winter here due to the lack of snow.
I see how storms here can cripple areas up here. It's crazy to think about how much snow the south has had with no way to prepare or deal with it.
North7
North Texas
SUV
After seeing so many pics like this from around Central Texas, I have never been so happy to have a single story house with no water pipes running in a ceiling or attic.
The destruction that has been caused, and still to come, is going to be astronomical and devastating.
Most newer homes are built with Pex plumbing pipe which is run through the attic, like my 2017 single story home.
I have a high/low memory thermometer in my attic, it hit 16 degrees this week. Even though the Pex has insulation on it my laundry room and one of the bathroom toilet pipes froze. I discovered the good thing about Pex pipe is since it is a flexible plastic it can help to avoid bursting.
codydb19
Cody
Silverado
I have a high/low memory thermometer in my attic, it hit 16 degrees this week. Even though the Pex has insulation on it my laundry room and one bathroom toilet pipes froze. I discovered the good thing about Pex pipe is since it is a flexible plastic it can help to avoid bursting.
I just heard this morning someone on the news or radio mentioning that flexible Pex piping. So yeah hopefully that will be a saving grace for many.
I went 48 hrs with no heat and no end in sight. So Tuesday the roads were good enough I could trek to my parents that had heat, power, and water. Was able to go back to my house today just to check on things, and had power but little to no water pressure. Everything was still dripping though.
Hopefully there is only one more night of this shit for us to make it through. But then the true test, what happens when everything thaws... 🤞
Ryuk
PA
I've heard in some areas will have water issues due to all of the burst pipes.
Vaquero61
Irv
NM
Bronco,F150,Wrangler
I'm presuming the Zoombie Apocalypse is when the undead have video chats and put cat heads and stuff over their images. :ROFLMAO:
With my Zoombie Outbreak Response Bronco, I'd see those Cat Heads etc on my Sync video chat screen onboard and I'd have to bail-out. I'd rather take my chances with Zoombies.
Ford Bronco TEXAS SNOW DAY IMG_2540
