Tailgate Hinge Over-Extension
RollingWreck
New Hampshire
22 Badlands SAS / Explorer
I noticed the paint on my tailgate hinge stop was chipped off the other day. When the tailgate opens if you don't do it carefully the piston doesn't prevent it from hitting the painted cast aluminum stop. Where I park is a bit of a side hill so with the weight of the tire it can easily open too far. I got some touch up on it but wanted to know if anyone else has had this same issue. Hss anyone installed the RTR tailgate limiter? Any Pictures?
Ford Bronco Tailgate Hinge Over-Extension Tailgate Stop - Chipped
Ford Bronco Tailgate Hinge Over-Extension Tailgate Open
Scape Goat
Rocklin, CA
2012 Nissan Frontier SV 4x4
I was looking at the Torx too
RHeinz
Ric
Houston, TX
Mine has a “rubber pad” to prevent paint to paint (metal to metal) contact. It appears from the photos you posted that you are missing these.
My hinges below.
Ford Bronco Tailgate Hinge Over-Extension 3CA09ED7-A087-49C2-AD72-154B20A6B902
Ford Bronco Tailgate Hinge Over-Extension 57BE6C3F-A29C-4D65-A968-C31BD9D02CD6
RHeinz
Ric
Houston, TX
Did the tailgate perhaps get damaged and repaired? Forgetting to put the rubber pads back in place.
Damage prior to delivery??
RollingWreck
RollingWreck
New Hampshire
Maybe damaged prior to delivery?!? I have only had it 6 weeks. I thought I t was odd that I hadn't seen anyone else post about this if it was a consistent problem.
BeachTiger
South Carolina
2019 Ford F150, 2022 Bronco Badlands
At first glance I thought this was welding spatter, but combined with the stripped fastener I'd bet this is paint spatter after a repair. That seems like too many imperfections to get past quality control if factory paint.
Ford Bronco Tailgate Hinge Over-Extension misc
M&M Beer
Marty
Ford Edge-F-150 Supercrew
Looks like a spray can paint job take it back and have it repaired
flip
Phil
IN
www.ruxerparts.com
Fords
Someone took these off to do an absolutely horrible spot repair. These come in a pack of 4, you'll only need two for after someone fixes the horrible paint issue.
W721479-S300
Ford Bronco Tailgate Hinge Over-Extension 1664289408134
  • Like
Reactions: Cat
RollingWreck
RollingWreck
New Hampshire
Thanks for the responses. I took it to my dealership yesterday and they are covering the repainting the hinges and pads.
