Switchworks_Kyle
Switchworks_Kyle
Kyle
Oxnard California
2022 Ford Bronco
Why cant it be made to utilize the screen?
I believe the cost of the screen would not justify the price point if we reduced the amount of switches. Im hoping our engineering team can come up with a solution to make it work though because the LCD screen is awesome and really changes the game.
I will be sure to update as soon as we know more on here!
KABQ
Aaron
Albuquerque, NM
Hello,
This kit uses Solid State technology, so it eliminates the need for fuses and relays going forward. The Module(Brain) will sit in your engine bay, the accessories(power and ground) crimp into the pig tails that run directly to the brain, and that's it!
Take a look at the link below and it will give you a lot more info on the kit. It is loaded with features and we try to make this a clean and simple usage kit for consumers. Its amazing!
https://ssvworks.com/collections/sw...lpha12-digital-smart-switcher-with-12-outputs
Please let us know if you have any other questions, Thank you!
I think the question was pertaining to accessing the vehicle fuse box with the brain mounted to the top of it.
Switchworks_Kyle
Switchworks_Kyle
Kyle
Oxnard California
2022 Ford Bronco
Yes good catch, Thank you! @KABQ
@Cardboardbronco So yes you will have to remove the 2 brain plate screws to access the fuse box as shown in the image below. From there you will have full access to the fuse box. The kit will remain intact and once finished with the fuse box you screw the two bolts back in and you are set.
Ford Bronco SwitchWorks Alpha12 Digital Smart Switcher Screenshot 2023-12-13 at 8.43.36 AM
