Switch soft top to hardtop?
zznalg
Southwest
JGC Trailhawk
First post here. If a 4 door Bronco is delivered with the soft top, can it be replaced with a factory hardtop in the future. If so, is it plug and play or does it require drilling and a difficult installation? Thanks!
Chrism81
chris
connecticut
Mazda
Not trying to be a dick because I am usually the one to say it's not a big deal to post something that has been talked about, but use the search for this. It has been spoken about a lot. To answer your question you can fit a hard top down the road but it will not have the hookups if you get a soft top first and the rumor is you can't order the hardtop separately as an accessory. You will have to wait till aftermarket and I doubt ford will have any extra hard tops anyway for a while. Welcome to the forums and search first or the animals on here will tear you apart
PrepVet
North Central WI
A bunch.
Yes. You will need to email Ford directly at the Assembly Plant and talk to Robert Hondors. He is the only one that can do it for you. There is also an additional $15,000 up charge for the service. Charged as soon as you email.
Big Island Bronco ?♂️
Motown, Motor City, DeTwah, Detroit
XJ Cherokee, 1971 Z28 R/S
Yes plug and play but no hookup for rear wiper/washer or defrost. Will have to purchase aftermarket kits for that. Unfortunately the soonest you'll be able to purchase a MIC top only from FORD parts department may be 12-18 months out.
grewhi
Greg
Seattle, WA
Maserati MC
The funny thing is if you look at the Soft top videos, they have the hookups. See image Not sure how to read that.
Ford Bronco Switch soft top to hardtop? 1623017060527
zznalg
Southwest
JGC Trailhawk
Thanks for the responses. True I should have searched but first time on the site.
Sounds like the issue is not perfectly clear. I'll keep learning.
Ripcurl
Badlands 2DR
Yeah, don't get run off by that stuff by any means, if you plan to stick around, the search function isn't the ultimate here anyway
So much uncertainty with the tops right now and going soft then hard later (if, when, how long), you won't even find a completely accurate answer anyway besides what we know currently about the lack of hookups
