Suspension options for BD
TuttyC
Travis
Boston
2021 Black Diamond
Hi I have a 4door 2.3 manual BD with 315 tires it also has a Zone 2” spacer lift. The ride quality is pretty horrible on road. Pot holes and speed bumps rattle my fillings loose. What are my options for better street ride quality? Thanks in advance for any advice.
kodiakisland
Arkansas
Ditch the spacers and get new coilovers. Lot's of options depending on what you want to spend.
What PSI are your tires at now?
kodiakisland
Arkansas
cjindna
DC
2022 Base Sasquatch 4 door 2.3l 10spd
Did you happen to loosen the upper control arm through bolts, settle the suspension at the new ride height, and then re-torque them?
If not, the NVH you are experiencing is most likely due to the UCA bushings being in a bind, creating unwanted preload on them.
