Summoning the ForScan Audio Lords
Changman927
Russell
2007 Tundra
I updated my "2021 4dr Big Bend" ACM module as detailed by many of the folks having the same goals as me (rear speakers to Speaker+Tweeter). Now my after market speakers sound fantastic. But suddenly the "ding do do do" (start up), and the "bong bong bong" (Check for carseat in rear seats) are loud as hell. I mean loud loud.
I also hooked up the Kicker Key 200.4, and turned the gain knobs about 45% up. Could that be the issue? If not... is there a forscan solution to lower the volume of all chimes? I have disabled the seatbelt chime using ForScan, but nothing on the spreadsheet mentions the check for carseat. I will disable the start/up chime if the steps are in the spreadsheet.
Karl_in_Chicago
Karl
Chicago
Did you try this suggestion from the thread titled "Every chime is louder after amp & speaker install"?
Karl_in_Chicago
Karl
Chicago
Thanks. This worked perfectly!
I can't take credit but I'm glad it resolved your issue. Might want to post a follow up in that thread so that others that might encounter that issue have further confirmation of a possible resolution.
Bill K
Bill
Allen, TX
Ford Bronco Big Bend 2 Door
I had the same problem after updating, and turned off the seat belt chime in Forscan. Can keep my sanity now.
Boomer75007
Carrollton,Texas
22 Bronco
What thread did you use to update your speakers, and ACM ?
