Sudden onset performance issues
kingcon99
kingcon99
Connor
Nevada
2021 Bronco BaseSquatch
I am sorry to say this sounds like exactly what happened to me. I'd take it to your dealer asap whether or not they can start work. If it is what happened to me, you won't be driving it and they'll need to start ordering parts asap - including a new engine. It took my dealership 33 days to get everything in and work completed. The parts were the main hold up. If your dealer doesn't have loaners/rentals like mine did, I'd call Ford asap and ask for reimbursement on a rental or for your car payment to be reimbursed. I chose reimbursement since I didn't want to pay up front for a rental and wait on a refund. Best of luck to you! It is very frustrating, but my dealer was personally fantastic throughout the process and Ford made it right by offering me free services for life.
Thanks for the heads up, I’ll keep the rental in mind when I take it in!
kingcon99
kingcon99
Connor
Nevada
Wastegate stuck closed sounds very possible and also would match the driving symptoms, if a gate is stuck close it would build max boost and blow the motor but it caught it and is now dumping boost and not building any (guessing). Honestly you guys are like the mob grabbing pitchforks for 2.7s when this doesn’t seem to match up to dropping a valve or blowing a motor at all. Besides when most 2.7s go they shut down and cannot be driven home.
Yeah I was able to get it home (about minutes) after the issue started, but haven’t driven it since, and won’t. Hopefully it’s not the blown engine but we’ll see!
Funkdoobiest
Buffalo
Ford Bronco Basesquanch First Edition
As promised. Checked hoses and at first glance I’m not noticing anything loose, though I’m inexperienced and likely have missed some.
You might be the Jackie Robinson. Hopefully not. No other engines reported with your date code but you you fall into the date range.
1975U15
2019 F-350 SD, 1975 Bronco
You’re probably right. No way the Ford intern would’ve responded with support if it was a blown 2.7.
Austin Bronco
Austin Texas
Triumph Street Scrambler
Sorry to hear that about your Bronco. Have there been any instances of the 2.3L having this problem?
Sav426
Savas
Bristol, Connecticut
2019 Chevrolet Silverado Trail Boss
First off I’d like to extend my sympathy to OP and hope this is resolved soon.
Second as a person new to Forums why are so many people posting in a manner that EVERY 2.7 is just a time bomb to explode.
Isn’t that a but hyperbolic? How many thousands of 2.7 Broncos are on the road and less than 50 have exploded motors??
I love the info in this community and the majority of helpful people, but geez there are some cremudgin’s in here.
Back to OP, I do hope this all works out for you.
Funkdoobiest
Buffalo
Not every 2.7. Just the 2.7s built between May and Oct 2021 for the Bronco. I believe I read it was estimated about 10k or so of these were made. We have 41 documented on here so far, and only have about 10% of Bronco owners on this site, so there are probably over 400 blown engines at this point that were built in the suspected time window. I think that is pretty significant. Combine that with Ford changing the faulty part to a more robust design, then yes I think every engine built in the suspect timeframe are in fact ticking time bombs.
1975U15
Sorry, but your statement isn’t the least bit accurate. Read the tracking thread.
https://www.bronco6g.com/forum/threads/2-7l-blown-engine-fail-list-41-so-far-march-7-update.31951/
The reported blown 2.7s are a small sample of an almost certain larger number. Not every Bronco owner is on this forum.
There are some(not many) that are very concerned they are on borrowed time given engines have blown with the same Julian date. I feel fortunate so far to be in the “clear gap” with a 21196 JD(knock on wood).
The hope is there is visibility and Ford addresses the matter as they are the only ones that actually know the truth. Hopefully in the OP’s case he is not added to the count and it’s a simple fix. His description does deviate a bit from others experience when the 2.7 blows.
kingcon99
kingcon99
Connor
Nevada
No response back as of yet from Ford on their DM request. Any updates I’ll post here. Thanks again everyone for the useful information thus far!
kingcon99
kingcon99
Connor
Nevada
Ford has responded requesting further information.
Bmisk19
Ben
Canton, MI
22 Badlands 2Dr 7MT
I had the same error pop up on my Bronco/Ford Pass app this weekend. Took delivery on Saturday and it happened on Sunday, after about 50 miles on the engine. I have a 2.3L Manual Badlands 2-door, non-Sasquatch. @Ford Motor Company
Ford Bronco Sudden onset performance issues 1646779967523
kingcon99
kingcon99
Connor
Nevada
Sorry to hear yours happened day one!! And with the 2.3L! Were you able to get it right back in, or are you playing the waiting game like I am for an appointment?
Bmisk19
Ben
Canton, MI
22 Badlands 2Dr 7MT
It’s going in on Thursday
Snowdogyyz
23 Ford Bronco Wildtrak
Read the thread and data and find out.
