- Xira
- Sep 27, 2020
- 11
- 884
- 1,607
- Wisconsin, USA
- 2016 Flex EcoBoost, 2022 Silverado LT
- Outer Banks
[Edited 11/14/2023: New method, new code, new everything]
A common complaint across the forum is that the Bronco will prompt "Return to [] mode?" instead of staying in that mode.
I decided to automate pressing [OKAY] using an Arduino -- a cheap hobbyist microcontroller. Under the right conditions, it will send the same message on the Canbus as if I pressed [OKAY] manually. For the rest of this post, I'm going to refer to the Arduino+Canbus+Code as a 'Xirabus module'
I won't be able to go into extreme detail because I don't want this to turn into a giant novel of every possible way to implement it, so please bear with me. I'll probably edit this a dozen or so times as I keep trying to decide how to phrase things. My apologies to mobile users.
In an effort to avoid cutting any factory wiring, I also used a number of tools the average person likely won't have handy, unfortunately.
Theory of Operation
The xirabus module constantly watches the messages on HS2-CAN. Messages consist of a 3-byte ID, followed by up to 8 bytes of data.
What I've found so far is:
Every new message xirabus reads, it increments a counter by 1.
From this point, it will wait until the following is true:
Once all these conditions are met, it will wait 3½ seconds for the instrument cluster to wake up, then send an [OKAY Button Pressed] message ten times.
The xirabus has no idea if the prompt is actually on-screen, it just blindly presses the button. This will also dismiss any other prompts such as Door Ajar or Accessory Mode Active.
Unfortunately the prompt is generated by FD1-CAN, so I can't detect when it's really happening.
I've included the option to have it automatically select between 2WD/4HI/4A by connecting a jumper wire to ground.
Similar to sending the [OKAY Pressed] message, this broadcasts the same message you'd produce manually pressing the buttons on the GOAT dial.
Hardware
The easiest but bulkiest combination is an Arduino Uno and Canbus shield. Almost zero soldering is required.
A little more compact but more soldering is an Arduino Nano and MCP2515 Canbus module. (Wiring diagram available here, or image search 'mcp2515 wiring')
Smaller yet, I designed a custom PCB that combines the Arduino's main IC (ATMega328p) and the MCP2515 in a single board.
This method requires a USBASP programmer (to set the CLKOUT fuse bit in the ATMega) and an FT232RL (to upload the code).
Honestly this method isn't cost-effective if you're only making a single board for yourself, considering most of the needed components are sold in groups of 10+. If you aren't already doing hobby electronics, what are the odds you have a spare 5v regulator or 22pF capacitor in the junk drawer? I also don't know where to host the GERBER file to share the pcb design.
Wiring
To keep things simple, only four wires are needed. Power, ground, HS2CAN+, HS2CAN-. Conveniently, all four are connected to the GOAT selector switch. Removing the power window switches gives you just enough space to reach in and disconnect the pigtail.
As mentioned above, I wanted to avoid having to cut any factory wiring. To make a Y-cable, I designed and 3D printed a pair of adapters to use Dupont terminals. It's not 100% oem-matching but close enough to work reliably. The Arduino connects in parallel to all four wires.
The pinout for the GOAT switch connector is as follows:
Program Code
Don't judge my methods, I'm not an expert coder. I typed half of this with the laptop sitting on my wife's lap in the passenger seat.
For posterity's sake, the command to set an ATMega's CLKOUT (Pin 8 becomes a clock output) is avrdude -p m328p -c usbasp -u lfuse:w:0xBF:m
Theory of Operation
- ID 167 byte 0 seems to indicate the engine state. 00: Off | 20: Cranking | 52: Remote Start | 72: Running | B0: Auto-Stop | B6/76: ASS-Restarting
- ID 167 byte 3 has something to do with the current accessory mode. It's 00 when engine off, 10 when engine on.
- Every ~300 messages, a message with an ID of 18A is produced when the car is in Accessory or Run. I don't know what it is, but it stops immediately when the car is off.
If the message has an ID of 167, it stores the values of bytes 0 and 3 as EngineState and AccState.
If the message has an ID of 18A, it resets the counter to zero.
If the counter reaches 1,200 it will assume the Bronco is turned off -- 18A stops being produced, but other IDs continue being broadcast for several minutes.
- 18A messages are being produced again.
- EngineState is not 0x20 or 0x52. This is to make it wait during remote starts, where 18A will happen but the instrument cluster isn't ready to display 'Return to [] Mode?'
- AccState is 0x10. This is to catch a condition where you stop the engine, but then restart it without opening the door.
Digital Pin 5: Connect to GROUND to select 2WD
Digital Pin 6: Connect to GROUND to select 4-HI
Digital Pin 7: Connect to GROUND to select 4-A
If no jumper is installed, the car will switch to the default for the selected GOAT mode like normal.Similar to sending the [OKAY Pressed] message, this broadcasts the same message you'd produce manually pressing the buttons on the GOAT dial.
Hardware
Wiring
Pin 1 | White/Red | VBATT |
Pin 2 | Grey/Blue | HS2-CAN (-) |
Pin 3 | Green/Orange | HS2-CAN (+) |
Pin 4 | Black/Violet | GROUND |
Pin 5 | N/C | N/C |
Pin 6 | N/C | N/C |
Program Code
