- Mitch
- Mar 11, 2021
- 28
- 2,364
- 4,110
- Cape Cod, MA, formerly Flagstaff, AZ
- 21 2 Door Badlands 6MT - Sold, 01 Expedition, 24 Tesla Y, 24 F-150 Lightning
- Badlands
Your research is correct, Powercore is the only aftermarket option that improves both airflow and filtration over stock. The Donaldson filter media is the same as used on Ford and Chevrolet diesel trucks from the factory.After researching various aftermarket filters, the trade off seems to be more airflow = less filtration but better power/acceleration or fuel economy. Or less airflow but, better filtration sticking with a paper filter. Personally, I'll stick with the better filtration over airflow.
While researching, I found Volant (https://volant.com/). If they design an intake for the Bronco that uses Donaldson Powercore G2 ultra-web filters, I'll upgrade to that because they filter better than paper and probably match the same airflow rate or slightly better.
I did a write up on the Powercore back in 2009 when I got a unit from Volant after talking to them at SEMA. I did before and after oil analysis, silica levels dropped with the Powercore. I’m not sure what happened to the pictures on the thread. The first filter was still looking good after 70K on my diesel truck when I replaced it.
https://www.dieseltruckresource.com...107/volant-powercore-intake-56k-death-230747/
Oiled air filters allow fine dust through that gets to the turbos and rings. Prove it to yourself by forcing some cheesecloth down the intake tube. It won’t come out clean.i have been using K&N for over 20 years, never had a problem. i just keep them oiled and clean them when they get dirty. being able to rinse them out just makes sense to me.
Donaldson Powercore is a dry filter, no oil used as it would ruin the filter media. I’m not sure what you are actually using, but Volant does offer regular oiled filters.Been running the Donaldson PowerCore filters in my Volant box on my Xterra for 16 years. I have two filters that rotate out, you need them dry after cleaning before oiling so this helps out. I use the K&N recharger kit that comes with cleaner and oil. I went this route because I hate single use stuff when there's reusable methods. Point is these filters hold up well over the years and I have had no issues with my MAF sensor getting gummed up with oil/dirt.
The dust getting through the oiled filter is real. Also, turbocharged engines strip the oil off the filter depositing it in the mass air flow sensor, intake path, and turbo.If you thing about KNF and other filter and air intakes are design to let more air in and if you in or do off-roading in area with dirt or lots of dust then you are sucking in that dust .I live in Vegas and I was going get a cold intake for my KL back in 16 and fond reading on jeep forums that people had lot of problems with sucking in dust and went back to paper filters and I even wrote KNF and AFE and they said best to use paper filters .
Oiled air filters are a relic of the carburetor era, and should be relegated to the junk bin now.
I’ll be sticking with whatever Ford ships on my 2.3L. The OEM’s do a solid job of engineering these things.
