MMR oil filter canister replacement (2.7 engine)
Chris21667
Southern MD
2022 Bronco Outerbanks, 2020 F350 Tremor, 2012F150
That MMR housing is next on my list to replace the factory housing. There’s no way I’m trusting a made in China part with unknown materials. MMR is a good brand and they build modular Ford race engines.
bronco_rat
So. Cal
Hello,
Is anyone using the MMR oil filter canister on the 2.7? Or is there another option, like the aluminum one on Amazon, that is a direct replacement for the plastic one, which broke the first time I changed the O rings?
https://www.modularmotorsportsracing.com/cart/index.php?main_page=product_info&products_id=1499
https://www.amazon.com/FT4Z6A832C-U...yirqeZboco4DWtOoJAwTBU3o2XxoCW-sQAvD_BwE&th=1
Just installed the MMR. Solid fit, significantly sturdier than the OEM housing.
Swapping out the inner stem takes a gentle hand. Be careful not to break one of the 4 tabs that holds it in the housing. (ask me how I know). Only thing I question was the 120ft lb noted to tighten it to. But Taylor at MMR confirm that was the right torque.
R1Bronco
R
Ford explore sport
If you can give me any tips on taking the stem out I would really appreciate it.....Thanks on advance
bronco_rat
So. Cal
You just have to tip and pull it out with a firm but gentle hand. I rushed it and broke one of the clips on the end so I just bought a replacement cover from Amazon and swapped the stem from it.
vicorjh
Jay
New England
2023 Bronco Wildtrack
120 ft-lbs? This doesn't sound right. The stock housing is 18 ft-lbs. I assume the MMR is using the two outer o-rings, why so much torque?
R1Bronco
R
Ford explore sport
Ok I will give it a try later...
Thank you
ScLeCo
Springfield
Charger Hellcat
120ft lb on an aluminum oil filter housing? Um no.
kr_1315
Kevin
Houston, TX
F150, Tundra, Explorer, IS500, '23 Bronco 2DR
No useful benefit to this product other than lightening your wallet.
