Stage Series Flush Mount Reverse Light Kit! | Diode Dynamics
Mikerider
Washington
Raptor, Ranger, Mustang, Focus, Explorer
any plans for a version with an Amber and white light vs the red/white?
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
www.diodedynamics.com
Ford Bronco
We don't have a flush mount SSC1/SSC2 product configuration with an amber backlight, white main beam, and flush mount front bezel.
However, to achieve this setup, you'll simply need a standard SSC1/SSC2 LED pod with a white main beam and amber backlight.
Example - SSC2 LED Pods:
Ford Bronco Stage Series Flush Mount Reverse Light Kit! | Diode Dynamics 1664219345412
https://www.diodedynamics.com/off-road-auxiliary-led/led-pods/ssc2.html
Then you'll need to swap the standard bezel for our flush mount bezel that's sold separately. This process is quick and easy!
Example - SSC2 Interchangeable Front Bezel:
Ford Bronco Stage Series Flush Mount Reverse Light Kit! | Diode Dynamics 1664219297320
https://www.diodedynamics.com/stage-series-2-led-pod-replacement-front-bezel-one.html
Finally, you can complete your own kit arrangement by purchasing our Universal Reverse Light Wiring Harness.
https://www.diodedynamics.com/reverse-light-wiring-kit-w-running-light.html
The information provided above will allow you to have an SSC1/SSC2 flush mount kit with an amber backlight and white main beam.
I hope this information was helpful!
