Sta bar games
BAUS67
redneck
Central PA
Found this on FB. Didn't know if posted somewhere else so thought I should post like this. Healy is playing with the sta bar disco. :ROFLMAO:
andi
@Admin. Front page
texasgreazer
Jason
Burleson TX
2020 Explorer, 2019 GMC Canyon
I wonder..
would an aftermarket manual disco offer more wheel drop than this set up. I've seen the mechanics on how this works hydraulically, just curious if it it still "limiting" travel at all?
BAUS67
BAUS67
redneck
Central PA
I wonder..
I'm not an engineer but I would say ..... No. Manual or Hydro travel would be the same.
Anything Squatched would be limited 10MM for fender rub. The way I understand it.
Apples
Nick
2022 Jeep JLUR, 2024 Nissan Ariya
I wonder..
That's an awful lot of droop for an IFS. I'd start worrying about binding the CV.
BAUS67
BAUS67
redneck
Central PA
Have you seen the videos from Moab or the Rubi yet ??
Apples
Nick
Of course. I wasn't saying the CVs would bind but going for much more droop than that would really start hitting the limit of what a CV can do. All evidence says they set up the suspension to maximize that travel while just avoiding that problem
BAUS67
BAUS67
redneck
Central PA
Yes it was discussed here months ago with engineers that worked on the project. Maximum wheel travel was the goal. More droop than up travel. Trying to maintain a better contact patch through out wheel travel. Lower COG with big tires. all kinds of techno stuff. (y)
texasgreazer
Jason
Burleson TX
I probably could have worded that better.
Understandable that this system would be designed within the context of maximum performance and safe drivetrain limits, but being a dedicated system, and hydraulically controlled, is it possible that completely disconnecting the standard bar would give more droop-at the risk of damage.
Is the limits of travel using this device the actual limits of the control arms/coilovers/bumpstops, or are safe limits of travel designed into the disco itself. To relate it to a different system, consider air ride suspension. It could be deflated to a "safe" psi controlled by a computer and lower the vehicle, but removing the bags completely would drop it more (though unsafe).
The only one's that truly know might just be the engineers involved in it's design, I'm mostly just thinking out loud.
BAUS67
BAUS67
redneck
Central PA
Read through this thread, it is only 5 pages, but it you watch for teocalimg posts, he explains alot.
https://www.bronco6g.com/forum/thre...uatch-package-for-my-hobbies.2151/#post-67467
Happy Trails (y) (y)
Flourman
Centennial, CO
2022 F350 Tremor, 2019 Beta 300RR
That’s an interesting thought. Maybe not bind going straight but at full lock. The Toyota stock birfield is pretty strong until it gets into full lock and one tries to go backwards. Then BOOM. I’m sure there will be situations where this happens with the stock CV’s but that’s what the aftermarket is for.
Used2jeep
Massachuvian
2007 Crown Vic P71
North7
North Texas
SUV
As the engineers design the Bronco in 3D modeling they can tell the limits of safe travel. This would then be further validated by testing and update the design as needed. Once this is complete they understand the design margins and the safe limits they are willing to sign up for to stand behind it with a warranty.
Can it move further, perhaps, but then you risk breaking something. To some this is fine, the cost of using their Bronco how they want. But understand, you most likely will be denied warranty coverage for the broken parts or secondary effects.
