SRQ Fabrications Spare Tire Delete Kit
srqfabrications
Matthew
Sarasota, FL
www.srqfabrications.com
2021 Bronco 2Dr
Direct Link: https://www.srqfabrications.com/store/2021-Bronco-Spare-Tire-Delete-Kit-p462655719
Starting Price: $329.99
  • Easy bolt-on installation that reuses factory hardware
  • CNC precision cut from ⅛” steel
  • Compatible with our Bronco rear bumper, stock bumper, and other equivalents
  • Includes all required mounting and wiring hardware, plate padding, and in-depth instructions
  • Relocates factory third brake light and backup camera
  • Includes easy bolt-on license plate lights
  • Includes built-in bottle opener grommet cap
  • Powder coating options are available
  • Hand-built and designed in the USA
Our prototype modular bumper is also pictured below. Frame-mounted recovery points, dual swingout capabilities, retain hitch, etc... More info to come!
kbBronco
Kyle
Carrollton, TX
2021 Ford Bronco, 2019 Honda Rebel 300
That is pretty damn cool looking.
Raptor911
Raptor911
Broadlands, VA
I was watching a video (I will post when I can find it) and they were talking about how if you wheel hard, your door will bend due to the weight of the spare if you have a 37 or a 35. Both guys in the video .. their rear door was bent.
dan79
dan
ma
08 f250
why do people wont this? I hate seeing jeeps with out the tire there too looks like u cheeped out and didn't buy the 5th set up
Raptor911
Raptor911
Broadlands, VA
you will consider it when you back door hinge bends OR you will get a rear bumper with a tire carrier.
srqfabrications
srqfabrications
Matthew
Sarasota, FL
2021 Bronco 2Dr
I was watching a video (I will post when I can find it) and they were talking about how if you wheel hard, your door will bend due to the weight of the spare if you have a 37 or a 35. Both guys rear door was bent.
I have seen a few of these too. I'm currently running 37s and don't trust the stock location. Our rear bumper will have dual swingouts so the weight of the spare tire will be on the frame and off of the tailgate. The 3rd brake light/camera portion of this spare tire delete kit will then move out to the swingout and the delete kit will remain on the tailgate.
srqfabrications
srqfabrications
Matthew
Sarasota, FL
2021 Bronco 2Dr
This kit was designed with our rear bumper in mind. While our bumper will work with a tire up to 37" in the stock location, we also will be offering dual swingouts for it. If you select that option, the spare tire moves to the swingout and you'll need a delete kit for the tailgate. The 3rd brake light and camera portion of the delete kit will then move to the swingout.
dan79
dan
ma
08 f250
no not me! id rather do this or something like it with my 37 on there. but thats just me i guess
Raptor911
Raptor911
Broadlands, VA
My solution is to run an aftermarket wheel that is 10 pounds lighter than the OEM wheel. This solution will drop 10 pounds from the rear door. This should help relieve the strain on the hinges.
BUT way too many guys here do the opposite which is add more weight to the rear door by running E rated ties or 37s
Raptor911
Raptor911
Broadlands, VA
in time we will see whether or not the solution below will work.
dan79
dan
ma
08 f250
that makes sense thank you! like I said tho I do see alot of jeeps with out ever having the spare, that bothers me. A swing out with it on there I would much rather see
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Anything you can do about the tire bumpers? They're kind of ugly sticking out all alone. Also I think a new rectangular CHMSL would look better than repurposing the original.
srqfabrications
srqfabrications
Matthew
Sarasota, FL
2021 Bronco 2Dr
Tire bumpers can be easily removed, just didn't in the photos. Bronco ends up having a different setup on it everyday while we design parts.
PWillette
Parrie
Maine
You're not alone...I like the reinforcement option, just not a fan of the RC version.
