Squeaking UCA - Brand New
Built2Wild
Bay Area
Motorcycle
I had some brand-new Pro Comp UCA installed a few months and yesterday was the first time I got them offroad and boy do they squeak. On road not an issue but when I hit some serious articulation then they squeal like a pig, any suggestions?
smelly
Massachusetts
2022 2DR Black Diamond 7MT
Loosen/remove the nut for the thru-bolt for the UCA and pump some grease into each zerk fitting (2 on each UCA) until you see the bushing start to separate a little bit. Put a little bit of loctite on the end of the bolt and reinstall the nut
Built2Wild
Built2Wild
Bay Area
Motorcycle
Loosen/remove the thru-bolt for the UCA and pump some grease into each zerk fitting (2 on each UCA) until you see the bushing start to separate a little bit. Put a little bit of loctite on the end of the bolt and reinstall the nut
Thank you!!
